Moode Audio Player for Raspberry Pi
Hi, just another friendly bump 🙂
-Tim
Hi Tim
Sorry for late response.
Yeah, I have PlainDac+
Anything else you want me to run?
Marek
amixer dump is here (alsamixer screen attached)
Simple mixer control 'DSP Program',0
Capabilities: enum
Items: 'FIR interpolation with de-emphasis' 'Low latency IIR with de-emphasis' 'High attenuation with de-emphasis' 'Fixed process flow' 'Ringing-less low latency FIR'
Item0: 'Ringing-less low latency FIR'
Simple mixer control 'Analogue',0
Capabilities: pvolume
Playback channels: Front Left - Front Right
Limits: Playback 0 - 1
Mono:
Front Left: Playback 1 [100%] [0.00dB]
Front Right: Playback 1 [100%] [0.00dB]
Simple mixer control 'Analogue Playback Boost',0
Capabilities: volume
Capture channels: Front Left - Front Right
Limits: 0 - 1
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Auto Mute',0
Capabilities: pswitch
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'Auto Mute Mono',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Auto Mute Time Left',0
Capabilities: enum
Items: '21ms' '106ms' '213ms' '533ms' '1.07s' '2.13s' '5.33s' '10.66s'
Item0: '21ms'
Simple mixer control 'Auto Mute Time Right',0
Capabilities: enum
Item0: '21ms'
Simple mixer control 'Clock Missing Period',0
Capabilities: enum
Items: '1s' '2s' '3s' '4s' '5s' '6s' '7s' '8s'
Item0: '1s'
Simple mixer control 'Deemphasis',0
Mono: Playback [on]
Simple mixer control 'Digital',0
Capabilities: pvolume pswitch
Limits: Playback 0 - 207
Mono:
Front Left: Playback 127 [61%] [-40.00dB] [on]
Front Right: Playback 127 [61%] [-40.00dB] [on]
Simple mixer control 'Max Overclock DAC',0
Capabilities: volume volume-joined
Capture channels: Mono
Limits: 0 - 40
Mono: 0 [0%]
Simple mixer control 'Max Overclock DSP',0
Limits: 0 - 40
Mono: 0 [0%]
Simple mixer control 'Max Overclock PLL',0
Limits: 0 - 20
Mono: 0 [0%]
Simple mixer control 'Volume Ramp Down Emergency Rate',0
Capabilities: enum
Items: '1 sample/update' '2 samples/update' '4 samples/update' 'Immediate'
Item0: '1 sample/update'
Simple mixer control 'Volume Ramp Down Emergency Step',0
Capabilities: enum
Items: '4dB/step' '2dB/step' '1dB/step' '0.5dB/step'
Item0: '4dB/step'
Simple mixer control 'Volume Ramp Down Rate',0
Capabilities: enum
Simple mixer control 'Volume Ramp Down Step',0
Capabilities: enum
Item0: '1dB/step'
Simple mixer control 'Volume Ramp Up Rate',0
Capabilities: enum
Simple mixer control 'Volume Ramp Up Step',0
Capabilities: enum
Item0: '1dB/step'
Hi Tim
Marek
Capabilities: enum
Mono:
Limits: 0 - 1
Mono:
Mono: Playback [on]
Capabilities: enum
Item0: '21ms'
Capabilities: enum
Item0: '21ms'
Capabilities: enum
Item0: '1s'
Mono: Playback [on]
Mono:
Limits: 0 - 40
Mono: 0 [0%]
Limits: 0 - 40
Mono: 0 [0%]
Limits: 0 - 20
Mono: 0 [0%]
Capabilities: enum
Capabilities: enum
Item0: '4dB/step'
Capabilities: enum
Capabilities: enum
Item0: '1dB/step'
Capabilities: enum
Capabilities: enum
Item0: '1dB/step'
Hi Marek,
Thanks!
PCM512x chip options will be available for PlainDAC+ in first Moode 2.7 update.
-Tim
In Moode 2.7 image it should default to ON for Pi-3 and for other Pi's the setting will not appear.
Do u by any chance turn it off at some point?
-Tim
Hi Tim
I don't believe so but I couldn't say for sure. 2 young children and very little sleep so anything is possible. Sorry. If I get chance over the weekend i'll redo 2.7 from scratch, as per how I did this one, and see how it comes out and get back to you. I've got to do it to upgrade my other pi3 anyway.
cheers Tim
tried on the fresh image..., just 1 and 3 line without quotes, right?, under /boot?
Correct, no quotes.
Just tested auto config and no issues.
To verify that it worked look at /var/log/moode.log and /etc/network/interfaces file. Auto config logs what its doing in moode log. The interfaces file should contain a section for wlan0 that has ssid and password from moodecfg.txt file.
-Tim
hello i´ve tested the moode 2.7 today and i´m having issues.
the setup is raspberry pi 3 (wireless) + hifiberry dac pro.
using minimserver on pc and bubbleupnp on adroid.
after 2 to 3 songs music stops, and lose connection to moode. i check on fing and i don´t see moode no more and i have to go and disconnect the power supply to do a reboot.
i was using max2play previously and never breaks (sometimes loose connection but don´t break). so i think it is a moode bug.
i think moode sounds better so i would like some help.
tks
After reading throug some raspi forums I found that loosing network connection generally is a known PI issue (so not moode related, maybe raspbian) and no one seems to know the ultimate solution.
One post I read mentioned to add the following code to /boot/cmdline.txt:
smsc95xx.turbo_mode=N dwc_otg.speed=1
It was said, it slows down the speed the usb-chip runs to 10 Mbit...
Even though I don't know if this applies to moode in any case, since then I have had no issues streaming from one PI3 with moode 2.7 to another PI3 with moode 2.7 ( at least for the last 30 Minutes which is way longer than any time before).
I will report, if this fixes my problem permanently.
GM
Having issues getting interface to come up in AP mode. I can connect my tablet to the pi, but cant get anything past that. what I have tried in browser"
diyAudio server HTTPS page
moode.local
moode
pi 2 Rev. B, Hifiberry Dac+ Pro, Edimax wifi dongle
Am I missing something?
Thanks,
GGM
If Android OS on Tablet then probably need to use IP address of AP (http://172.24.1.1).
Many Android based OS's don't support multicast DNS (mDNS) and thus not able to resolve the .local domain. The only fallback to access AP is IP address.
-Tim
tks
It could be the issue described in the link below regarding Hifiberry DAC+ Pro causing issue with Pi-3 WiFi.
http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-415.html#post4789594
Hifiberry is aware of issue and investigating.
-Tim
Recently i clicked on the update and it updated to the latest version. Now i cannot see anything in the browse tab also when i go to MPD, i get "mpd-config: connection to mpd failed" Is there anyway i can revert the update please. Thanks for such a great work!
Updater is pretty basic and thus there is no undo mechanism. If u think an update may not have completed successfully, it can simply be reinstalled by deleting the file below then clicking "CHECK for software update" followed by INSTALL.
/var/www/update-r26.txt
If u still have issues after reinstall then post back the contents of moode log.
/var/log/moode.log
-Tim
