New Mark Audio Pluvia Seven
Bill - the 11 is very new to the market, and not likely in all resellers' inventory.
We're still breaking in our first test pair which were shipped directly and almost certainly arrived earlier than larger orders to Madisound or European / UK dealers.
Should I be worried about soldering with the P7? I'm using the 4% silver stuff...
Just pre-tin and don't use any thicker wire than #20 for internal wiring, and you shouldn't be there long enough to worry about softening the wiring tabs' molded retaining clips. If however, they do soften a bit, just lightly clamp them with needle nose pliers while cooling. Our first pair of Alpair 5.2 protos were swapped between 5 or 6 enclosures, and I found that to work well.
Operation Stealth Solder successful. 16ga. pre-tinned wire. I threw together a speaker and listened briefly with a very crappy A/V receiver. Promising...
I ran a quick measurement of the speaker. I'm showing with and without 6 bands of parametric eq and with a 1/12 oct. frequency dependent window. Unfortunately, there is a pretty severe breakup at 20.5khz that makes the impulse response look ugly. I don't think it's an audible issue. I did some listening (just one speaker) with the eq as shown along with a Linkwitz transform and some linear phase baffle step compensation. It sounds really good.
