Arduino based LDR volume and source selection controller
Hi Paul, thanks for the reply. The pre board I am using already has a relay resistor volume control which sits on the output side rather than the more conventional pot then gain stage so I was hoping just to add input switching with ht bypass without the volume control for this project. Is that possible with this setup?
Gordon
Gordon
You mean just use it for input switching with IR control?
Finally finished mine...
