How to build a 21st century protection board
But as it happens on the version I have got, the two middle ac connectors are connected together - registers as short on the multimeter. So I have connected the centre wire to them.
The outer wires are connected to either end. there is a 76V potential difference between the two outer secondaries.
I don't think this supply will work with a center tap transformer
Is your transformer connected to the supply correctly?
Yes I believe so, as long as the GOSS screen should be earthed, that is the only thing I am not sure about. It measures 76V across the 36-0-36 secondaries when checked.
Did I send you the supply or is it your own?
Yes, it is from the kit. It is a compact supply board.
It actually runs fine with just the relays and transformer in play. It's only when adding the supply that the issue occurs.
I'll take out the supply board and have a good look over it at the weekend. ensure everything is installed correctly / check voltages at various points on the board and then reply again.
Did you test each stage of the build using a Mains Bulb Tester to power ON?
230r of soft start resistance suits a 100VA to 150VA 230Vac transformer.
For a 700VA 230Vac I would use 30r to 40r with a T3A mains fuse.
Thanks all I think that the board I have is bad according to Jeff. I'm going to check tomorrow and if the only electrical problem is the diodes then I'll run those point to point off board.
I think the output voltage markings on the silk screen may be wrong too but I've not got far enough to confirm. If they are the only two faults I can fix both issues and move on.
I've got the PSU boards working temporarily by building a small bridge circuit off the board. Jeff is going to send me some new replacement boards but I'm working up until then. Speaker protection boards also now assembled and tested.
First time around they tripped with dc offset, and there was indeed 1.2v of offset as I had not calibrated that channel!
All good now, will put up some photos when tidied up a little. Thanks for all the help so far!
Flashing bootloader on my single supply boards the ghetto way. The ICSP programmer I ordered from ebay didn't arrive in time
Now the boards are ready to be fully populated. 🙂
At the same time I flashed bootloader to a new atmega 328 for the uno board.
