Tube Phono Preamps
Yes, but looking for trends only, what if you have a circuit, let's say it uses a 6AU6 into a 12AU7 as mosquito's does, and let's say spice says it'll get 0.1% THD at 1V rms output. I take that figure of 0.1% THD with a large grain of salt. Perhaps it's really more like 0.3% THD in real life.
Hmm... 0.309% is what I'm getting using Ayumi's 6AU6 model and my 12AU7WA/6189 model. The quality of your model(s) has a great deal of influence on the accuracy of the THD results in LTspice or any other simulation software.
BTW, here's a Laplace with a correction factor for gain. I.E. 5mVin=5mVout.
Code:
LAPLACE=(1+3.18e-3*s)*(1+7.5e-5*s)/((1+3.18e-4*s)*9.8759)
Hey cogsncogs, thanks for your input on this.
Following kevinkr's findings that real life THD will be 3 or 4 times worse than the spice prediction, that 0.3% THD you're getting with 5mV input would translate to 0.9% in real life. That would be about what I'd expect from this pair of tubes, especially with the 6AU6 set to such high gain.
Is the 12AU7 Ayumi model that far off? (It could be.) Would you mind pointing us to your 12AU7WA/6189 model? I'd like to try it out and compare it to the Ayumi model.
Using your 12AX7 model (from the Mazda datasheet), I've been able to get an RCA-style RIAA (with Ayumi-model 12AT7 cathode follower) to output 1V RMS with <0.05% THD (all 2nd harmonic) in LTspice. Assuming that that result is 4X more optimistic than real life, I could expect something around 0.2% THD at 1V RMS out into 100k ohms in real life. That's my figure to beat.
As I've mentioned elsewhere, I built an RCA RIAA preamp with cathode follower for my brother, something like 20 years ago. It's power supply is primitive; just your basic, unregulated CRCRC, with a basic DC heater supply (not regulated). I had it in for a checkup and got to hear it again. It's really pretty good; quiet enough for its intended use with MM carts. It may not be the highest resolution, most detailed phono stage you've ever heard, but it's really easy to listen through. I can see why it's a classic. Were I to do it over again, I'd improve the EQ and use a ZVN0545 source follower to buffer each 12AX7, and use regulated PSU's for both plate and heater supplies.
Code:
Thanks for this!
To use this, do I place an input signal AC voltage in my schematic and place this LAPLACE= string as a spice directive in my schematic? Or does this string have to be written into the .ac directive?
It's not perfect, but untill we get a better way to model triodes, it will have to do.
Code:
* 6189/12AU7WA LTSpice model
* Modified Koren model (6 parameters): mean fit error 0.238074mA
* Traced by Wayne Clay using PlotDigitizer and Curve Captor v0.9.1
* on 3/22/2014 from Tung-Sol datasheet.
.subckt 12AU7WA  P G K
    Bp  P K  I=
+ (0.02753937477m)*uramp(V(P,K)*ln(1.0+(-0.1580044043)+exp
+ ((1.904441567)+(1.904441567)*((26.38270501)+(23.18833909m)
+ *V(G,K))*V(G,K)/V(P,K)))/(1.904441567))**(1.309056183)
  Cgp G P 2.2p ; 0.7p added
  Cgk G K 2.3p ; 0.7p added
  Cpk P K 0.6p ; 0.2p added
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 12AU7WA
For other simulation software including LTspice, look below: 🙂
Code:
* 6189/12AU7WA macro model
.subckt 6189  P G K
    koren6(0.02753937477,-0.1580044043,1.904441567,26.38270501,23.18833909,1.309056183)
.ends 6189
* 6189/12AU7WA Spice 3F4 model
.subckt 6189  P G K
    Bp  P K  I=(0.02753937477m)*uramp(V(P,K)*ln(1.0+(-0.1580044043)+exp((1.904441567)+(1.904441567)*((26.38270501)+(23.18833909m)*V(G,K))*V(G,K)/V(P,K)))/(1.904441567))^(1.309056183)
  d3  G K dx1
.ends 6189
* 6189/12AU7WA PSpice model
.subckt 6189  P G K
    Gp  P K  VALUE={(0.02753937477m)*limit(V(P,K)*log(1.0+(-0.1580044043)+exp((1.904441567)+(1.904441567)*((26.38270501)+(23.18833909m)*V(G,K))*V(G,K)/V(P,K)))/(1.904441567),0.0,1.0e16)**(1.309056183)}
  d3  G K dx1
.ends 6189
* 6189/12AU7WA PSpice model for Micro-Cap
.subckt 6189  P G K
    Gp  P K  VALUE={(0.02753937477m)*limit(V(P,K)*ln(1.0+(-0.1580044043)+exp((1.904441567)+(1.904441567)*((26.38270501)+(23.18833909m)*V(G,K))*V(G,K)/V(P,K)))/(1.904441567),0.0,1.0e16)**(1.309056183)}
  d3  G K dx1
.ends 6189
.subckt 6189  P G K
    Bp  P K  I=(0.02753937477m)*uramp(V(P,K)*ln(1.0+(-0.1580044043)+exp((1.904441567)+(1.904441567)*((26.38270501)+(23.18833909m)*V(G,K))*V(G,K)/V(P,K)))/(1.904441567))**(1.309056183)
  d3  G K dx1
.ends 6189
* 6189/12AU7WA CircuitMaker model
.subckt 6189  P G K
    Bp  P K  I=(0.02753937477/1.0e3)*uramp(V(P,K)*ln(1.0+(-0.1580044043)+exp((1.904441567)+(1.904441567)*((26.38270501)+(23.18833909/1.0e3)*V(G,K))*V(G,K)/V(P,K)))/(1.904441567))^(1.309056183)
  d3  G K dx1
.ends 6189
Try this 12AT7 Mazda model:
Code:
* 12AT7_mz3 LTspice model
* Modified Koren model (8 parameters): mean fit error 0.149064mA
* Traced by Wayne Clay on 3/3/2014 using Curve Captor v0.9.1
* from Mazda Belvu datasheet
.subckt 12AT7-mz3  P G K
    Bp  P K  I=
+ (0.02790974004m)*uramp(V(P,K)*ln(1.0+(-0.01128450125)+exp((2.13112283)+
+ (2.13112283)*((98.95747475)+(-218.6570898m)*V(G,K))*V(G,K)/sqrt((24.5022294)**2+
+ (V(P,K)-(-33.23286842))**2)))/(2.13112283))**(1.220154214)
  Cgk G K 2.9p ; 0.7p added
  Cpk P K 1.7p ; 0.2p added
  Rpk P K 1.0G ; to avoid floating nodes in mu-follower
  d3  G K dx1
.ends 12AT7-mz3
12AT7-mz3 Curve Captor:
Well, I corrected my simulation settings as suggested by Hans Polack (timestep error)
Then compared Ayumi 12AU7 model against cogsncogs 12AU7WA
Huge difference in THD but, 3d harmonic with both models is held to -120dB under the fundamental. What changes is 2nd h, at -80 dB with one model, -60dB the other..
(we are talking in the Tokarev circuit, in the exact same conditions, w/o any changes)
I'm looking to build a tube phono preamplifier (first time) for a recently completed Tubelab SE 300B, and would like some recommendations for kits or schematics. <snip>
Most of what i know, I learnt from Allen Wright's pre-amp cook book. So if you want valves - here are valves. According to his web site - this was the pre-amp that Allen used.
the Lapalce string is to be placed as value, using the symbol editor (click on the symbol)
Do I take a certain kind of voltage source from my pre-existing symbol library, and apply the LAPLACE string to that?
Here's a schematic you've uploaded with a LAPLACE statement in it:
Is the LAPLACE statement applied to the E1 voltage source? If yes, then what is that E1 device called in the LTspice symbols library? I haven't used that one yet...
Thanks for any help you can send my way, and my apologies for drifting off-topic here.
do you have any pics to share? i exchanged emails with him, very nice fellow...
hope he lives longer despite his health concerns....
No photos, sorry. Patrick was down here in Melbourne looking after health concerns so hopefully things will improve. Send him another email I am sure he would be pleased with some correspondence.
On a brighter note - we had a nice Japenese dinner together and I showed him the schematic of my diy mosfet amps. 2 days later I get an email back with a new detailed schematic with lots of improvements. He is a very clever designer and very generous with his time and advice. I just need the time now to implement these improvements.
Cheers, Hazard
Sent from my SM-G900I using Tapatalk
