Very simple quasi complimentary MOSFET amplifier
To find what's happening on the circuit, could you please measure these areas:
1. Voltage across Vbe multiplier, Q4, from C to E of BD139. Should be 1.90 volts
2. Voltage across LED and series 4004 diodes. Should be 3.25 volts
3. Voltage from gate of Q6 nmos to base of inverter, Q5. Should be 5.19 volts.
4. Voltage across R20, for 0.47R this should be around 50mV
5. Voltage at output wrt ground, should be 0mV but I think it's about +2? (positive?)
6. Voltage wrt ground at left side of VR1, should be -3.2V.
7. Voltage wrt ground at right side of VR1, should be -3.82V.
8. Voltage at wiper of VR1, and voltage at base of Q1, all wrt ground.
A lot of these pins/points are not exposed on the topside of the amp. I will have to flip amp upside down but then there is no heatsink. I am flipping amp to side and getting back pins where possible.
1. 2.13v for 400mA current.
2. voltage across 2 red LEDs is 3.50v
3. nmos G (-) tp Q5 base (+) is -5.06v
4. R20 voltage is 90mV across 0.22R (I adjusted this for 400mA current).
Normally I run 80mA but trying to see if XO distortion goes away - no.
5. -1.3v is lowest I can get it
6. -4.76v (I think this is what you are calling the "right" side of the vr1)
7. -3.50v (side facing top edge where Fastons are)
8. voltage at wiper of VR1 is -3.50v
Thanks.
X
It's too bad I am having so many problems because it's a cute looking little amp as it fits these Dell Pentium CPU heatsinks perfectly.:
562729d1470033250-very-simple-quasi-complimentary-mosfet-amplifier-quasi-build-pair.jpg
Hi XRK,
We are getting very close to fixing this.........
HD: This gives us a total bias voltage of 2.13+ 3.50= 5.63. This is a heavy bias; you could increase the resistance in the BASE to EMITTER of the Vbe multiplier so that the voltage across the entire shebang reduces to Thimios' value, that is 5.19V rather than 5.63V. This should reduce the idle current around 100mA, and if it's 400mA it should be then 300mA, but to be honest this is a bit too high. I would not use more than 150mA. Even then it will be pretty warm, this is 0.15 x 70 = 10.5W, about what it should have.
HD: This confuses me. What is the voltage from GATE of nmos Q6 to BASE Q5 pnp? It should be 5.20V, no more.
HD: 90mV across 0.22R is 410mA and you will be dissipating around 28.7W across your heatsink for each channel. This is far too high and you need to reduce your bias generation by increasing Vbe resistance on the Vbe multiplier as above.
HD: You need to put the black probe on the ground, negative probe is always on GROUND, and red probe on the output. If you do this should get +1.3, not negative, and the next question is this: CAN YOU GET THIS VOLTAGE UP CLOSE TO ZERO?
6. -4.76v
HD: This is wrong way around. I should read -3.5V (black on grnd, red on left side of VR1 near leds) and -4.76V wrt ground on the RIGHT side of the VR1, near 10k 1W R6. Is this correct?
8. voltage at wioer of VR1 is -3.50v
HD: Have your removed R4, and replaced R5 with 33k? What is the voltage, with black on gnd and red on base of Q1, wrt ground now?
This will identify this..........
Hugh
Hi XRK,
I gotta get into this and try to help. I'm sorry you are in trouble, but it will be very simple once we find it. Measurement is the best way.
Now, index our circuit. You are working from Prasi's Rev 4.3 here?
http://www.diyaudio.com/forums/solid-state/255427-very-simple-quasi-complimentary-mosfet-amplifier-68.html
This is #675.
1. Voltage across Vbe multiplier, Q4, from C to E of BD139. Should be 1.90 volts 2.051V
2. Voltage across LED and series 4004 diodes. Should be 3.25 volts 3.665V
3. Voltage from gate of Q6 nmos to base of inverter, Q5. Should be 5.19 5.09Vvolts.
4. Voltage across R20, for 0.47R this should be around 50mV (0R33) 38mV
5. Voltage at output wrt ground, should be 0mV but I think it's about +2? (positive?) 0.5mV
6. Voltage wrt ground at left side of VR1, should be -3.2V. -3.667V
7. Voltage wrt ground at right side of VR1, should be -3.82V. -4.33V
8. Voltage at wiper of VR1, and voltage at base of Q1, all wrt ground. -3.98 / -1.835V
That should be enough to identify all currents and voltages around this circuit.
Good luck!
Hugh
Couldn't sleep so I hooked it up and measured. Rails +-36.3V
You can see my findings above in red.
Thanks for all the help guys. Sorry to leave you hanging but had to stop last night at 3am. Will investigate again later today following your tips and questions to debug.
I am just realizing that I may be the first to make this amp with this particular layout. This layout is different than what Terry made from his own etching? I wonder if there is an issue with the circuit and layout as implemented here as I have same problem on both boards. So if it's a user error like cold solder joint or bad trace - odds of same error on both is low.
So, if I am the first on this particular layout - I can recalibrate my expectations and not feel as frustrated as it would be indeed sort of like "path finder" mode.
Luckily, in the past on Prasi's layout - they all fired up and ran from the get go. This one is a special animal - clearly off the beaten tracks and should be given more consideration accordingly.
Thanks for all your patience and help though. I would indeed be at a dead end without your expertise.
It's connected according to the layout with proper orientation of pin 1 where square pad is. If it was backwards I would not be able to effect bias current adjustment at all. I just noted on the layout diagram that blue LED orientation is incorrect as drawn. It would be opposite of a Zener as they work in reverse polarity breakdown voltage. I can confirm that amp hits the rails if LED is in backwards.
562037d1469629680-very-simple-quasi-complimentary-mosfet-amplifier-quasi-lay-rev4.3.png
Note that this is not the board I have as mine says not tested and has no provision for heatsink on Q3/5
Hi X,
Terry used the layout from post #333 http://www.diyaudio.com/forums/soli...imentary-mosfet-amplifier-34.html#post4765108 .
Bangle H ordered the PCB from the same post. So PCB layout works, so there should be a problem with build unless its a manufacturing issue, which I doubt very much.
reg
Prasi
