Rockford 301s Won't power up
The lamp initially lights up due to the inrush current charging the secondary capacitors. If the capacitors remain charged, the inrush current is significantly less.
The Z44 staying cool is good. The only reason I want it to survive is so that testing can continue and you can get the parts ordered.
Did you try adjusting the bias to see if the light would get a bit brighter?
IS the power LED still lit?
Do you have positive 15v on pin 8 of the various op-amps and negative 15v on pin 4?
When you initially power the amp, does pin 14 of the LM339 go from 0v to approximately 10v (after a second or so)?
The power LED stays lit anytime I have it hooked up. I've been removing it while I come on here so as not to overheat anything.
Do op-amps have board designations beginning with U? For example U101-A?
This might be a good point to end for the night because I will need to study up on where all of these test points are.
See attached.
