Sony vFET Amplifier Part 2
Check the dissipation capacity of the cases offered by the diyaudio store. you should have at least that per side.
The bracket should fit nicely with two of the heatsinks you linked, and give enough dissipation.
What temperatures do you usually have in the summer in your house?
in summer we have most of the time max. around 24°c , but some few days up to 28°c in the listening room.
CSX1 & CSX2
Hi All,
In anticipation of the availability of the kits I've been reading and re-reading the Sony VFET articles, both part 1 and 2.
One Question I have is that in the schematics for CSX1 and CSX2 in the Part 1 Article, there is an 8R resistor at the output.
Anyone know if that is meant to indicate an 8 ohm speaker load or whether that 8 ohms is supposed to be in parallel to the speaker load? If parallel, why and what wattage rating?
Thanks!
Greg
Totally off-topic, but here is my planned output stage mounting scheme for the flexible CSX/VFET projects. The goal was to avoid the cost of the angled extrusion as nearly anyone will CnC a piece of flat stock. I am not sure how well it will work, but we will see. It's mounted to a Conrad Heatsink in the photo through a piece of copper bar. I need to get properly sized teflon tubing for the TO-3 pins and screws and I think I am ready for some fireworks.
Either the angle or this could be pretty easily hand drilled with a bit of patience
The holes for the pins seem small - might give extra fireworks!
Ah, you really did mean tubing! Here's the angle specs for the one pair per side. 1/4" aluminum "L" angle is pretty easy to find if you don't find the "t"shape. But it might help people making flat plates too...
http://www.diyaudio.com/forums/atta...68-sony-vfet-amplifier-part-2-diy-bracket.pdf
luvdunhills flat approach would give more room for a PSU probably.
Here's the pin spacers we used
http://www.mcmaster.com/#94639A300
They are shorter, 3/16" because the made in Italy brackets are actually 5mm thick.
McMaster-Carr does have 1/4" long sleeves also
