New multi-channel Hypex build for LX521
Alright, I'm not happy with having to do another rectangular cutout, but I'm at least satisfied that this switch will safely handle two of the SMPS1200 supplies.
C1350ARBB-602AW Arcolectric | Switches | DigiKey
250VAC, 150 amp rated inrush current, 20A continuous. Maybe it will be nicer to get a little illuminated pushbutton switch on the front, and soft start, but for now I think that this one on the rear panel is going to get the job done safely.
Well, I've finally got four channels and one power supply attached to the heat sink! I've also located and installed a 20 amp DPST paddle switch, rated for motor use. I'm moving forward assuming that the surge current would be given as worst case (240V operation) and it will be a lot less here with my 120V mains.
I did the thermal interface plate by hand, laid out with calipers and a center punch, and if I had it to do over I'd probably send that out to a machine shop too. Oh well... it saved me probably $100 to do them myself, and they'll work.
The speakers these are meant to drive are mostly assembled now, so I'm quite eager to wrap it up.
Clean !
Now you are ready for the wiring process 😀
nice work on the heatsink and plates. Could you share the source?
