100W Ultimate Fidelity Amplifier
thank you
I think I should made a clone layout of this layout from mister Mile 🙂
Best Regards
Juan
Previev post i missed one negative track from resistor 22K.
Now is correctly..
And i copy silkscreen...
I have built the A Class PSU and it is very clean. Maybe even cleaner is the Jung Regulator that OS and Jeff designed. A lot more parts though.
All are fed from a 26-0-26VAC transformer. Measured without a load. Each are set to approximately +-24VDC.
The first three all measured about the same. Very low ripple. Surprisingly though, The PSU I built for my Self Preamp shows less noise and ripple than the first three. It shouldn't but it does. Not sure why.
