Very simple quasi complimentary MOSFET amplifier
very simple
Increasing the the value of C8 from 68pf up to 150 pf i can't see any improvement.
Then i tried the opposite.
Decreasing up to 12pf.
Here results.
+/-30v
idle current=150mv
offset=0mV
R load=6R
820mV RMS inp.=17V RMS out
48W RMS/6R
A problem uploading images,i must resize all pictures.🙁
Here
Other test after requirements😉
This surprised me - congratulations to Thimios, thinking outside the square - I guess the quasi transistor should be slowish, maybe a BD140?
Hugh
Why we must use slow transistors?😀
I have a new surprise!
This time C8 position is EMPTY.
To eliminate all gnd issue two channel scope used as floating gnd(Math configuration).
Read amplifier output voltage on voltmeter left on the bottom.
Read test frequency on freq.meter in the center
1)just beffore clip(1Khz)
2)soft clip(1Khz)
3)hard clip(1Khz)
4)soft clip(10Khz)
5)Hard clip(10Khz)
6)Soft clip(20Khz)
7)Hard clip(20Khz)
8)50Khz
9)100Khz
10) Rise time.
To be continued....
Stay tuned!
Thimios,
Hmm, very interesting. Are you using 1381 or BD140 for quasi transistor?
I think this is a perfect square wave at 10KHz, almost perfect.
Not too much slew rate, and slight asymmetry between rise and fall.
It does not use rail voltage too well; I guess the clip is at around 53Vpp? The clip is clean and seems to recover quickly.
NOW, what do you think of the sound quality?
Points to consider:
Bass
Midrange
Treble
Depth and width of image
Sound of trumpets, drums, and violin?
Clarity/Resolution with complex music, eg orchestra
Vocals - natural?
Warm, or cold
Engaging over time, non-fatigueing?
Does it make you tap your foot?
Ciao,
Hugh
Hi thimios
Congratulations!! All these waveform images are very interesting but even more exciting would be a detailed listening report after you've spent some quality time with your prototype, with your favorite speakers and favorite music.
Christian
Thimios,
Points to consider:
Bass
Midrange
Treble
Vocals - natural?
Warm, or cold
Ciao,
Hugh
Hi thimios
Christian
Hugh,i'm using KSA1381E
I'm using TTC5200 & IRF240 as output.
I want to thank astx who donate me with a lot of parts!
I will post the schematic as built soon.
Ranchu,this need time and a second channel for listening in stereo.
This need more ears too.🙂
Unfortunately i haven't exotic speakers.🙁🙁🙁
I will try to repeat the test using a higher voltage power supply +/-43V.
Thanks Thimios,
Most appreciated; don't worry too much about the speakers - if the amp is good then you will hear it very clearly through midfi speakers. OTOH, bad amps sound bad even with very, very expensive speakers......
Clever of you to find the oscillation was a bad earth. Shows us that grounds are very important, and easily lead us to the wrong conclusion.
Hugh
Thanks Thimios,
Hugh
I must thank you and Ranchu for one more good amplifier in my collection.😉
Thanks Prasi,without your pcb never i have try this!
I can't resist to try Thiacomodi pcb too...
very simple
Look at this.
The first picture has been taken without separate input.GND
The second picture has been taken connecting the inp GND to star GND.
Listening the amplifier using headphones when nothing connected to inp.i can't hear any hum but i hear hum when inp.connected to sound card out.
Prasi,i believe that this sigleton inp. amplifier need a separate inp gnd to star gnd.😉
Look at this.
Thimios, I had the same problem in my VSSA with 10R ground lift resistor. When I shorted that resistor, hum problem went away. could this be the same case here? Just guessing here.
reg
Prasi
Hi guys
I'd like to build a couple of these amps, has a group buy been done for the PCB's? If not are the original designers happy for me to use the board design posted here and get some boards made?
Don't want to upset anyone by taking their designs..... no it's not going to be a commercial operation!
Will the changes being discussed at the moment affect the overall board layout?
Thanks guys, keep up the good work.
Dave
Look at this.
Finally there isn't any problem,this hum was a matter of gnd loop.:cheers:
I spend some time listening Patricia Barber cafe blue.
No original disk not a flac either,just in mp3 from youtube.
I'm surprised from the vocals and crystal clear and strong cymbals.
This simple amplifier have something magic. You must listen to this!:checked::checked::checked:
