100W Ultimate Fidelity Amplifier
I actually think the FX8 is better.
Thanks, I'm actually waiting for your suggestion. Any comparison with AX11?
:up::up: my recommendation too!
reg
Prasi
Thank you sir. Have you compared this to other Apex amps?
some time ago APEX mentioned that one of his best sounding amplifiers was A14,(a version with opamp at input).iIt was built by a member and he declared very good impressions indeed.
Yes, I saw that while skimming through the thread. I think it was actually still4given. I was a bit unsure upon seeing the OP amp on the input side however. Now still4give prefers the FX8.
Apex Audio actually said the FX8 was his favorite "simple" amp and the A40 was his favorite amp overall used with P30 preamp.
http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-667.html#post4650931
Yes FX8 is my favorite simple small amp, and if you compare complexity vs sound quality it is beter than A40.
I like simple amps there is A9, AX9, FX9, AX10, AX11...
I have built the FX8 and FX8 Bimo Mod, and the FH9 variant of the FX8 (vertical hex FET) and can attest they all sound very good. The FX8 Bimo Mod with super transistors choices and nice layout by Prasi is probably the best of the FX8 series.
This is a fairly simple hex FET amp that is currently on of my favorites - it has a very low noise current-drive front end. With the 53v SMPS and CRC output filters, I am getting 0.1mV ripple at the amp output with the audio inputs grounded. A very quiet amp. I like it so much, I actually am making a case for it.
Can I suggest we start a new thread outside of APEX Audio?
I am SUPER interested in SMPS for Amps and am willing to contribute.
You might have to start one in Class D forum. If anyone is interested, there is a thread there on a $20 450w 53v dual rail SMPS that is very clean. These are still available on eBay. I am using one on my amp now and it works very well: with a CRC filter I am getting 1mV ripple.
http://www.diyaudio.com/forums/class-d/281698-abletec-53v-dual-rail-450w-supply-20-a.html
