100W Ultimate Fidelity Amplifier
here scheme
KT 973 it's PNP transistor , corrected schematic ....😉 Would be great to know about transformer ,primary and secondary winding's ,turns ,diameter of wires etc.🙂
my 300 watt transformer, the primary winding comprises 42 turns of 0.8mm, the secondary 12 + 12 turns of 1.25mm wire, coil 12 volts -0.8mm 5 turns. can write the dimensions of your transformer, I found the data you need for winding
Hi. I've been trawling the thread for information but it's a really big thread.
Can you guys recommend which Apex amp is best for the following specs :
Single pair output stage ~ 50watts
For playing "vocals" type of music
I want to hear the "air" that I usually read about in reviews. 😀
AX11?
SR50?
I'm looking at either the P8 or P30 as preamp unless you can recommend a matching preamp for any amp you suggest.
Thanks guys.
PS : Yes, the recommendations will probably be subjective but I need a place to start.
