Newbee build: PA03 amp (LM4780)
Make sure that the heatsink is not connected to anything. When the LM4780 is mounted the heatsink will be connected to your negative raw voltage through the backplate of the IC.
Did you have +- 35 V or something?
BTW: I can guarantee that the chip was OK when you got it from me.
Yes I had +-35V before mounting the heatsink. After I mounted the heatsink I installed the Voltage regulators and the LM4780TA. What's curious to me is, that also the relays are not switching. How long does the timer take to switch the rleays?
I just measured again +-32V.
Do you have approx. 2-3 amps from each rail, without blowing the fuses? Nothing else is hot?
When I check your pictures, it seems that you have quite much tin and not so well molten. On the component side I see that the tin hasn't flown up through the holes. This doesn't need to be a bad thing.
If you just want to replace the chip you can cut all pins and then it will be easier to clean the holes. Try also to analyze what when wrong like solder bridges, short circuits in bad places etc.
Unsoldering was fine. Chip is already removed since yesterday. I was able to remove it without cutting the legs. now waiting for a replacement chip. farnell didn't accept my order, since i don't have my own company.
here's my measured voltages on the chip pins without installed chip. what is curious to me is the 0.3V where i should have 0V.
ground when measuring with the multimeter was the contact between the large electrolyte condensators.
i could imagine that the voltage regulators are creating a offset to the ground of the power supply when the chip is not installed. but maybe this was the issue what caused my problems.
http://imgur.com/8K3J6yD
