F6 Illustrated Build Guide
Good news..
I discovered that on the very first powerup of My F6 build that my Bespoke Tube pre pumped the driver cones.. dramatically, at on Or off.
Turned out that My tube pre also significantly reduced the sound quality of my F6 . Enough to think it was a Mid Fi piece. It isn't 🙂
Odd, because that pre worked quite well with previous amps.
Regardless, when I replaced the pre with a simple cobbled together stepped attenuator I got Massive sound quality improvements.
On reading your experiences, I'm even happier that my pre is gone
Besides it had unresolvable background noises... slight, but persistent
Whereas the F6 is Dead silent.
It was suggested I build/use a BA3 as pre.. now working towards it.. slowly
Hopefully there is something useful in all the above.
Yes that volume bit did cause pause
I'm having NO issues with volume at all with the 10k pots.
Bass that I can feel in my belly and Sweet extended detail.
More loudness than I can tolerate if.. I crank it.
Sounds are very good, even on the 3rd floor of my house (floors are open/vaulted as explanation)
System is on 1st floor. Large volume/space possibly helps acoustics.. certainly doesn't seem to hurt.
Frankly I'm well pleased.. as is.
But hey, I defer to better experience/judgements.. willingly.
On course to a Ba3, and if it improves sounds ? Bonus !
Benefits of BA3
1) Extra gain for insensitive speakers.
2) Adjustable harmonic distortion. Tune it to however you like.
Benefit of using volume pot
1) Less gain stages in signal path. Always a good thing.
2) F6 has it's own buffer at front end, no need for separate B1 buffer preamp. It already has one.
Success My first PASS amp build comes to life.
I am the proud owner of an F6 amp Many Thank's To Nelson Pass for being so generous.
6L6 for the fantastic build guide.
DiyAudio for the boards and members willing to share there knowledge.
Many Thank's.
Steve.
Upload your images to the Mac, beware of where you place them for quick access.
Use built in iPhoto to shrink the photos.
How to Shrink a Photo in iPhoto: 10 Steps (with Pictures)
Most digital cams has a selectable image resolution.
800x600 or lower is an OK size for uploading to the forums. <=400 KB is good.
I'm sorry I don't use Mac or I'd give you better instructions.
Vince
Thank's gent's.
Steve.
