The Best DAC is no DAC
Pic how I connected the mute, is OK?
Ray do you know if the wew Diyinhk USB to I2S 768Khz - DSD512/1024* Converter http://www.diyaudio.com/forums/vendors-bazaar/290015-new-usb-i2s-768khz-dsd512-1024-converter.html is pin compatible with the flip-flop & SE boards?
Felipe
I can't give a definitive answer but I imagine it presents DSD-L and DSD-R on its header pins; that's all you would need for the SE board. For the Balanced board you need a master clock signal for the FlipFlop device; section 7 of the user guide on the webpage describes a hack to get this.
No isolation/reclocking though, would have to be offboard should you consider it necessary.
Ray
