System Pictures & Description
845 amplifier with a fishtank for projectile avoidance.
Uses 6sn7 for first stage and 112a for drivers.
Driving horns from 200hz up.
Wooden case is from a discarded table.
Top view
Speakers
18 inch woofers are driven by a stereo receiver. Not much power is needed for the woofers.
There are some weird effects there. If mouse is on the browser window you have grey text on a grey background. I get from your equipment you like grey 😛. If you move the mouse out the browser window its still grey on grey but almost legible.
BTW what's a 'Butwrt'? Sounds painful, hope you can get ointment for it!
Yes, the cut and paste from a Word file resulted in the strange colors. You can read it If you hover or drag your mouse over the text. "Butwrt" yes, like Mrs Butterworth.
My 3 way speakers, started off as active with using a minidsp. Ended up
changing them to passive set-up recently.
Speakers were made by stacking CNC'd plywood layers, bass section has wall cavity mass loaded with lead.
Midrange/Tweeter baffle and insert made from aluminium, insert was to allow SS ring radiator to be changed
to Ribbon.
Crossover points, 350Hz & 2800Hz
Drivers:
Scanspeak Ring Radiator
AudioTechnology 18H mid
AudioTechnology 2 x 10A Woofer made to suit sealed enclosure.
to Ribbon.
Drivers:
Nice speakers! For the passive crossover, did you build using the same parameters you had programmed for MiniDSP, or you came along with a new setup?
I only used the same crossover points l ended up with in the Minidsp, l prefer the passive version over the active, the sealed bass from 4 x 10’s is pretty impressive even without any low end boosting done when it was active.
Good...I am changing from active to passive on my DIY 2-Way bookshelfs. Doing the same, using the parameters (XO points and gain adjustment-LPad) I had in the active.
two way bass reflex
This is my first speaker .
For the calculus i have used an old paper by
Patrick j. Snyder n°1307
I have implied a low cost 8" woofer for P.A. and a tweeter
vifa from my old two way esb cdx .
The case is double layer and the sensitivity is about 90dBspl.
The cross-over is made using the Allen.B guide and have a first order for each way
(thanks Alllen.B) .🙂
sound ...
Looks great! How does it sond ?
The principal aspect of the sound is the stability of the scene this is made by an a half
first order cut off over tweeter and woofer cells . 🙂
The case don't have a audible resonances and the behaviour in frequency is next to the
closed box to increase the velocity response . 🙂
At start i was undecided among a single way TL and a bass reflex two way. 🙂
I remember Pat Snyder from SpeakerLab here in Seattle. A very bright guy and quite interesting to listen to!
Altec 604
Altec 604D reconed by Great Plains Audio to 604E.
9 cubic foot cabinet. GPA design crossover. One inch baltic birch. The front is double thickness.
I built 2 of them. About 170 lbs. each.
