The simplistic Salas low voltage shunt regulator
How can we wired the JFET: d+g one leg and s the other leg or etc...? wich JFET: sk117, sk170, etc?
Idss is measured with G+S and D as input.
This operates in a circuit as well and gives a good CCS.
One would not normally connect D+G and use S as output.
Except that jFETs are reputedly virtually symetrical. One can swap D & S and get virtually the same performance, particularly with those intended for RF duty.
But this would be D+G and S as input, not output.
Yes 3mA IDSS is good. Only check the Vout is still safe as it should become slightly more.
The Ref-D does not care about minimal to work steadily, only know that you can use less CCS as the spare current becomes more sufficient with little load.
After changing R1 for 2R (I don't have 2R2) and the SK117GR for R6, now Vout 5.158VDC current 316mA (0.631V across 2R). Some pics:
1st left connected the FF & isolator both powered R-D
2nd BiB only powering Amanero
3h connected only FF without isolator powered R-D
