A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
I don;t know specifically about Ian's reclocker, but it has proved possible to use something like the BBB Botic driver to output the 2 data channels for left and right in the correct format for the deck boards and therefore do without the main board. I am very interested in this, but I have yet to try it
I try to run the DDDAC with IANs PCM Baord with no luck. Sound comes out but with heavy noise :( I guess littel disaligment of the clock or LR signal..
For volume control, opted for the CS-3310.
Here driving in either NOS-DDDAC or DSD modes Japanese midrange compression drivers YL-35000 in a quad-amps setup.
Disabled Account
Joined 2002
Hello,
You could subscribe to their newsletter. I am sure when boards are available they will write about it in their newsletter. After all they are in for the money.
Of course Doede will also be informed and the news will pop up here too.
Maybe the first batch ( if i am right i read somewhere it will be 100 boards) will be sold within one week. Just a few people needed that want to build a 4 board dac ( like myself) and 100 boards are gone soon.
Maybe just wait for the first reactions and start buying with the second batch.
Greetings, Eduard
Hi!
2 months ago i tweaked my DDDAC with the CCS-boards and the tentlab-shunts for the analog side. i have 3 decks and was quite happy. but today, it made a little plopp and now the left channel is louder than the right (both play music). i messured the output of the right channel and between neg-pos there is .0.9 DC, between neg-GND 1.8DC and between pos-gnd it is 2,7 DC.
any ideas for help?
thanks, mario
Hi!
any ideas for help?
thanks, mario
Sure, please check if all chips has the right voltage supply. And look for bad connections between the 3 decks
Hello everyone. I asked for some help fault finding last week and received a response from a couple of members, see below.
After testing the voltage from the two power supplies I now realise the 12v was actually reading 25v so I am guessing I have fried something or everything? In my defence the 12v was brought as a built and tested 12v supplied so I didn’t check the voltage. Anyway a lesson learnt.
I tested the positive and negative outputs from the mainboard all read 2.48v
The dac boards read the same on both sides:
BCK 2.44v
Dat nothing
LR 2.49v
And on the other side of the dac boards the positive and negative (A and B) all read 2.49v
The output (RCA) I am getting a reading of 00.4v
Sorry about the lack of any technical terminology but I am learning and starting from a very basic point so I would really appreciate responses to be as basic as possible.
Thanks in advance!!!
Measure the DC voltages at the output - disconnect the transformers first. Ensure the symmetrical DC reading of around 2.5V is present on either channel.
It seems that as you change the loading by turning the pot, the sound cleans-up, as you said. so check the I/R resistors connections and the output transformers orientation and connections.
Check the Iref voltage as well - this will tell you if the Vcc's are okay and if the DAC IC's are okay.
The fact that you are using S/PDIF input, and the fact that you are not getting light from the sampling frequency LED's tells me that your motherboard soldering might be bad / oscillator is not connected properly, or the voltage regulation is off.
DAC IC's might get damaged if you power up the DAC boards with no clock present at DAC inputs - either from XMOS, or from 8804 receiver.
So, a bit of faultfinding seems to be in order. This information is also available on Doede's website
Good luck,
Nick
So what are they supposed to output? What did you tell the Ian board to do so to speak?How did you connect it? Small drawing may be or pics ? The DAC boards need 24 bit right handed I2S delayed 32 bits on one channel. Is that what the Ian board outputs?
Hi Doede,
don't get me wrong, it is just an experiment.. your design work's perfect.. also with IAN's FIFO connected via I2S .. it sounds fantastic.. IMO best DDC solution compared to Wave IO, Amanero and JL Sounds.
Additional I want to try to feed the DAC boards directly from IAN's additional I2S to PCM board .. it's just an experiment and i would share the result here because some users may be also interessted.
btw.. Output Format of I2StoPCM attached.
Sorry I should have said in the last post that I need guidance as to how to further locate the fault and how to fix it, or at worst whether I should cut my losses and buy a new mother board and dac boards, in which case which components should be OK from the old boards to use in the new.
thanks again
Can you clarify how many dac boards you have and what ohms your i/v resistors are?
If you're stuck, I don't think I'm too far from you and could help you do a quick sanity check of a few bits if you can wait a week or so for my work to quieten down a little?
If you can post some pictures up here of your current setup, that would help people point you in the right direction too.
James
Thanks dwjames, you have no idea how grateful I would be for your help, where are you based? I brought the dac over a year ago so a few more week waiting wont make any difference.
Anyway here are a couple of pictures for folk to look at.
The setup is basically two decks with components I received from audio creative including the cinemags as the output caps.
trying to work out which the I/V resisters are, once I have I will let you know the value and the reading I get with the multi meter.
Thanks once again
