Hi Ton,
if you want to use two Red Baron DAC´s parallel with the onboard I/V stage, you must connect it like this:
1st - Every DAC module needs all parts of the I/V stage, expect the I/V resistors. Adjust the DAC output to 0V (DC-offset of the TDA1541A).
Don´t forget to make the small modification and switch the source and drain of the MOSFET like in this picture !!!
2nd - The output of the current buffers on each DAC module (inner four-sided point of the I/V resistor) must be connected together (parallel).
3rd - You need only one pair of I/V resistors with 250R value on one DAC module (four-sided / round point).
4th - You connect the DC-Reference Module as followed:
From DAC module
Ref. (Audio out) --> Ref. +5V
GND (DC Digital) --> GND
From DC Ref. Module
GND Ref. Left --> GND RCA Left
GND Ref. Right --> GND RAC Right
You could see it on this photo
5th - Trimm the RCA GND to 0V
That´s it. 😉
Cheers
I am just about ready to build a Red Baron Dac, using two Red Baron v5.0 DAC´s in parallel with the onboard I/V stage. Please let me know if there are any major changes to how it is done from the quite ancient post featuring the v3.0 boards above?
Thanks in advance!🙂
Hi Oliver,
I want to try the dual red baron setup and was curious how you soldered additional DL and DR U.FL sockets on I2S to PCM board. Did you scratch the pcb to get the ground contacts or did something else?
https://www.flickr.com/photos/dvb-projekt/9487078400/in/photostream/
I scratch only the contacts. If i am not wrong, Ian has updated his board with two U.FL sockets now...🙄
Thanks in advance!🙂
For the V5.0 you can omit the MOSFET modification. The rest is the same.
Got these at the post office today, thank you very much Oliver 🙂
Perfect!
Package arrived today in the USA! These boards are really impressive close and in my hands compared to all of the pictures I've seen. Great work Oliver!
- Aguaazul
- Aguaazul
- Aguaazul
Thank you very much and have much fun!
Oliver
Package arrived today in the Hungary 🙂.
Thanks !
Dear Oliver:
The package arrived and the boards inside are in perfect shape!
Thank you very much,
Antonio
Hi Oliver
Not delivered yet!!Please check and confirm.
curryking
you could see the actual status attached.
Best,
Oliver
Hello, friends of the 1541a.
Has anybody tried using Beaglebone Black or Odroid C1+ with direct i2s output with the Red Baron? This USB to i2s thing is becoming a bit to complex for my liking with elaborate computers, USB-isolators, regenerators and whats not. And with some reviewers reporting that the plain old Spdif sounds more musical and dynamic than USB I'm starting to think that simpler may be better. Any views and/or experiences?
The day after I got them, they looked like this 🙂
Pics of three boards, two done and one waiting for a few parts.
Hi Mayday, I am about to start accumulating parts for the build and would appreciate some close up photos of your completed unit.
thanks
kp93300
- Group Buys
- "Reference" TDA1541A DAC with I2S-BUS architecture
