SlewMaster Project Boards
Hi jwilhelm,
I am considering building a pair and currently have nothing. Can you PM me with price and details. I really like that you are in the same Country / Provence.
How far away from Georgetown are you?
Best, Chris
Hi Jeff,
Many thanks. I'm not in a rush, so you can take your time. I looked your town up and you're right. It's not that far away at all. Maybe some day we can sit down and have a beer (or something).
I don't have anything for this build. Are you doing the voltage amp stages as well?
Best, Chris
Hi Jeff,
Outstanding! Many thanks.
I haven't been following this project, despite my strong interest in this one. I would really like to use J-Fets, cascoded, in the front end if possible. A CFP output stage would be extremely cool. The plastic outputs, but I could use TO-3 outputs if need be (but that would also probably mean a triple darlington arrangement).
Anyway, that roughly describes where I would like to be. That depends on availability at the end of the day.
-Chris
Hi Jeff,
-Chris
This sounds more like a Vzaichnko design than one of Ostripper's. OS uses BJT inputs and EF3 outputs in his designs. He tries to use easy to get inexpensive parts whenever possible.
Valery did the CFA-CFPx2 amp. It had bjt inputs but had a Hexfet CFP output. It's lower powered (140W?) but sounded excellent. He's got some other amazing creations too.
Hi Jeff,
Well, I wanted to build one of Pete's designs. I just wasn't sure if he did versions that used the configurations listed. I can either adapt the amp to use J-Fet inputs, or design my own, but Pete is way ahead of anything I can do.
So if it's BJT input and triple out, that's what I'm building. How about the outputs? Are they flat mount or TO-3 mount?
-Chris
Hi Jeff,
-Chris
The outputs are two rows of plastic devices flat mounted. They are spaced out enough to comfortably fit 5 pairs of MT-200s.
A question for the former participans from Europe of this groupsbuy done and deliverd by Evanc(USA).
Did you guys had to pay any custom(duty) fee?Last time I bought two amp modules for 100 USD and had to pay 40 Euro fee.I don't want to pay this for 4 pcb boards which cost 40 USD
Yes that's them.
