100W Ultimate Fidelity Amplifier
hi sir alex mm and rohin sir this is my apex sr 800. i use in 150k thermister instead 150k resister
My PCB layout (AX16Mod) edited and produced by friend of mine.
Hi
Can someone share the circuit for these amplifier. The one posted next to BIMO's post does not match the components (parts) location(s).
Ready to make the PC boards based on these layout.
Terry you didn't posted listening impression after a couple days burn in.. (I would like to build one amp from Apex..)
If you burn in your amp at least 30 hours or so please share with us
Greetings
Usually I design an amplifier with more than 1V peak/1V/uS slew rate. It mean, with +-35VDC PSU, it must have more than 35V/uS slew rate. The requirement of the minimum slew rate to get an amplifier have sound 'airy'.
By using TMC compensation, it can have high open loop gain at high frequency. Then, it can have lower THD at high frequency. You can always hear more detail at high frequency.
Previously, I have designed typical Blameless topology with TMC compensation. According to my friend who compare my amplifier with chip amp (LM1875 and LM3886), my amplifier is better at high frequency.
