Pitchfork pre-amplifier
I put 100r resistors in series with r22, r23, 32 and 33. Now the heatsink run stable at 59C. That's more then I'm comfortable with, but it's ok for testing.
It plays music through spooky ips and 5p Slewmonster and works fine. It seems to be more neutral then the dcb1 buffer, but it's hard to say since I haven't listened to my stereo for a couple of days.
Looks like everyone is ditching the TO92's. The company I used to work for up until about 1 mpnth ago, got out of that business in 2006/2007 - no money in it (i.e. the TO-92 package).
Time to get used to soldering SOT23's! Easy to do if you use a fine tipped soldering iron and some 0.8mm solder.
I finally got around to mount the transistors on the chassis below the board. Now it runs cool and I can put the lid on. 🙂
I am soldering down .5 mm pitch IC's with an iron. How are you re-flowing?
When I used to hand etch, I just used a toaster oven. I liked how parts would self align themselves.
Since I've switched to Chinese boards I've ran into problems with parts moving while baking. I think I'm trapping air under the parts due to the silkscreen outlines under the parts. I'm in the process of building a better temperature controller and I'm liking going to need to use stencils for the paste.
How does it sound? Is your volume changes still pop free?
It sounds great! I have been using it for a while using a big heatsink clamped to the small aluminium sink before I relocated the transistors, no pops or other noise.
It took a while to get used to the sound compared to the dcb1 buffer, the pitchfork sounds more transparent.
It really brings the slewmaster to life when I crank the volume. 🙂
