How were this measurements done? (Parameter, Equipment)
With a Rohde & Schwarz UPA3 audio analyser. We've got some nice oldschool equipment laying around 😎
Hm, but I just remembered the lowpass filter, 22kHz of the UPA was set. At the time I didn't put much attention to it, as I thought I'm only interested in the audiorange. Maybe I should do them again with the LP disabled.
Hi, We all know the Vol Pots supplied with the 3116's are crap. Anyone know of a decent quality pot that can replace the stan😕😀dard issue
If my dual chip's pot is crap I sure don't know it. It stays maxed while a tube preamp controls the volume. Take the money you'd spend on a pot upgrade and put it towards a tube preamp.
Maybe you should bypass the pot (is it possible to rip it off the board?).
But why? With near SET quality sound I'm leaving well enough alone.
If indeed it is always on max. If not ignore wiki and select proper value pot.Maybe you should bypass the pot (is it possible to rip it off the board?).
Resistor Power Rating for TPA3116D2?
Hey all,
Putting together a little bluetooth radio project and I'm wondering what Power Rating I need for the resistors used in the Typical Application schematic in the Datasheet.
Any suggestions?
Hey all,
Any suggestions?
Hey everyone. Wondering if anyone might be able to help me out. I'm putting together a little bluetooth radio project and am using the TPA3116D2. I'm using the typical application circuit from the datasheet but I'm curious what power ratings I need for the resistors.
Thanks!
Thanks!
If 2.1 also take values 3116evm for synch, "typical" circuit values do not function.
http://www.ti.com/lit/ug/slou336b/slou336b.pdf
24V SMPS
Parts Express is selling a quality 24V laptop brick for $10. (ends today)
24 VDC 4.75A Power Supply with 2.5 x 5.5mm Plug and LED Indicator
EA10952
EA10952
I got two, didn't try them out yet, they are for gifts.
but they look nice, maybe not as heavy duty as the 24v unit that comes with their tk2050 dta100 amp--and not a grounded 3 prong plug like that one either.
Also, be advised that the price may show on web as 24.50, but when I added it to my cart it dropped to $10.
That's a great price.
These are the same bricks that Dell($24) and Gateway sell for laptops. See the second link in my original message for mfg specs. I have the tk2050 dta100 amp as well. The brick that came with it is delivering 24.4V. This one from PE is delivering exactly 24V. I am listening to mine now powering a modded YJBB board. Sounds great!
I feel ripple spec is very high, max 360mV ?
How can someone decrease that?
C-L-C filter
I thought that only a few capacitors will do it. It needs more than this huh?
Could you be more specific?
Dual chip question.
On my dual chip 3116 amp the R13 position is empty. I've seen some ad photos that show the same, but I've also seen photos of the amp that show a resistor in place. Can anyone tell me what value that resistor might be? And does anyone know if that resistor is really necessary? My amp sounds just fine except for lots of hiss, although in my system the original red board amp sounds a lot better.
Thanks.
Thanks.
Thanks.
Have a look at my posts on: http://www.diyaudio.com/forums/class-d/276622-2x100w-tpa3116d2-2-chips-each-pbtl-6.html#post4538194 so don't worry about R13 (10K) ... your board is configured master/master ... unless you specifically want to run as master/slave, in which case you'll need to add R13 & change the gain setting resistors on the slave chip or on both chips, depending on the gain you're chasing
Re hiss, none from my board, just an almost inaudible whooshing sound with no audio, ie: whoosh can only be heard with ear 200mm or so from speaker
I rolled the four electrolytics with 1200uF/35V FMs ... for no reason other than I've experienced quite a few failures with cheap electrolytics. The FMs are a lot taller than the original, but that's not a problem in my case
j.R.c
If you want functioning master slave, you'll need to replace the capacitor next to r13. There isn't a functioning master slave chinese dualchipboard, just because TI has displayed wrong values in datasheet from day 1 and by "accident" forgets every time they update datasheet. The chinese probably think they sourced fake TI 3116, and found solution to have equal right and left channel by removing synch link and by either putting both 3116 in slavemode or both in mastermode.
So, I measured the outputs of my amp on an oscilloscope. Looks like there are a lot of artifacts of the switching frequency after all. I don't think they will have a lot of impact on the sound quality? If yes, how can I filter these out? My LC filter has now a cutoff at 27KHz iirc
Imgur: The most awesome images on the Internet
- Class D
- TPA3116D2 Amp
