" . . . DIY has little social value beyond a community where genuine performance for the sake of it is the goal. One of the reasons I enjoy this forum"
It figures. My wife has declared me unsociable on many occasions. I prefer to spend Saturday night in my den with a soldering iron in hand.
This is not the way of a logical or ordered mind.
Saying 'it's ok people get me' is a cop out.
I am sure Bruno really won't lose any sleep because you poo poo his designs because I recommended them as a starter for discussion. I won't either.
I am not debating you for points. Just making comments based on experience and on tests as well. I dont even care as much as others do if I dont correct typo and misspelled words and bad grammar. To me this is just texting here.
I havent poo-poo'ed his design. I poo-poo'ed your recommendation based on your comments and expressed attitude re. excellence of work being elevated to the level of fine art.
THx-RNMarsh
2. Again if you are selling it's OK, but in DIY where is intellectual and technical challenge in that?
And, when you go All Out..... it ends up sounding more accurate as well.
Thats just from my 50 years R&D in it and still learning. Which includes rooms, speakers et al. But some of you who like the challenge to do better, go all out in each area and see where you end up..... it actually just keeps getting better.
Just like video just keeps getting better with higher rez and other 'small' yet complex details. I cant wait to get a 4K UHD player and source material for my 4K UHD display here in my loft over looking Bangkok. Holograms are coming
-Richard Marsh
Agree - its the intellectual/technical challenge that is the interesting part.
There are many intellectual/technical issues and solutions which I would say reaches the level of Fine Art.
-RNM
Richard,
On the 0.1% thing I mentioned, it is in consideration of all the other distortion sources in the signal chain. If you change yor speakers, or the room layout and the sound changes (now that is EASY to detect), why beat yourself up of a hardly detectable level of distortion in an amp? Better to work on your speakers and secondly convince your wife to go with your acoustically optimized layout for the living room IMV.
Hi Bonsai . You know I respect your work. So lets get into this a little deeper.
If we have a recording chain of say 5 pieces of electronics to go thru for a recording and on playback we have 3 pieces.... and each produced at normal use output levels of 0.1% thd..... at times the max distortion we are listening to could be as high as 8 x 0.1% added to the original sound. To be guaranteed to never exceed 0.1% system total, we need 0.1/8. The fewest stages the signal has gone thru, I find sound better (less total distortion). At the same time it makes the just noticeable detection (JND) threshold a little lower as well.
In my particular case, I DO have speakers with no more than 0.1% in the mid range and listen in the near-field. So, for me the JND threshold would be lower. I come up with a conservative 0.05%. For others if might be less. So that is .05/8. If we need each piece of gear to have less than .006% in my example of 8 pieces of gear in a total system chain. If this were the case we would hear the Master source reproduced in our home pretty much the same as direct from the master source. When I use my headphone amp (<.001% thd) and low distortion headphones for music downloaded and Mastered for HiRes it is very close to live.
THx-RNMarsh
You chase guests away too with talk about amplifiers, cars, and various techno dribble, hey ?
(Happens to the worst of us. I chase them in the parking lot if they express their desire to leave, sometimes knock on the side-window of their car for a last addendum)
Hi Richard.What I found was high SNR in particular sounded more accurate even if the THD was increased.
Figure that out.
THx-RNMarsh
To be expected.
In my experimentation/experience how the circuit/system handles/reacts to signal included noise and circuit stages self noise changes the subjective experience big time.
The spectral nature and dynamic characteristic of system self noise is a large part of what separates good systems from exceptional systems.
Very interestingly this system noise behaviour can be changed at will.
For example try ferrite clip on filters in different circuit positions - to my ear the result is drive out of the room awfulness.
I have different clip on filters that render any system to entirely pleasant.
The degree of improvement varies according to the SNR quality level of the system.
THD including mild clipping becomes quite irrelevant.
This concurs with your findings.
Dan.
By all accounts, the simplest decent sounding amp - albeit low power - has to be JLH's 10 watter - but in the split rail version (Richard, this is less than the idle power on your amps . . .
Even NP was impressed . . .
Hi Bonsai !
I wonder why nobody have tried to made that simple JLH 10 - 15 W A class amp variant but now using modern very fast complementary BJT OPS , using same simple JLH topology with only four BJT supplied from split rail PSU ?
Regards !
Hi Richard.
To be expected.
Dan.
You have misunderstood what Richard wrote (it looks you've edited his post), SR (Slew Rate) not SNR (Signal Noise Ratio).
It used to be certain music was required to drive away guests who overstayed their welcome. But a far more effective way to at least make some space around oneself was to engage in conversations about electronics with another. I'd barely get mid-sentence sometimes in a small group before all but one would move away.You chase guests away too with talk about amplifiers, cars, and various techno dribble, hey ?
Yes, some people take satisfaction in being able to afford the best, and some from being able to achieve it cheaply. Which has more social kudos ? Is it taboo to suggest that achieving good results cheaply is even possible in some circles (not just high end audio)?Very droll....
My personal philosophy is to always get the best that you can afford. I never let a lack of money prevent me from doing the best I could..... it would just take longer as I could only buy a part or parts once in while. II would rather save for a few months to get the better part. I had a car once that I spent 10 years working on it to get it to be all I wanted it to be. By then laws had changed and I couldnt get it to pass smog... 2-3 years more to clean up the exhaust. But in the end, it was a great fun machine.
THx-RNMarsh
THx-RNMarsh
You are correct .You have misunderstood what Richard wrote (it looks you've edited his post), SR (Slew Rate) not SNR (Signal Noise Ratio).
Does not change what I have said though, and in fact reinforces what I said.
Dan.
Hi Jacco !
I know that NP article , it is just one very good variation of old JLH idea/ A class amp design, which basically is SS translation of Williamson tube amp ,
My idea is different , simple singleton 10-15W A class amp without BJT phase spliter , which relay on modern very fast complementary power BJTs for OPS , here is the rough basic schematic .
(Note , there is no CT on secondary coil of main power Transf. , just virtual floating ground formed with two 680R power res.)
Depends who you ask.
Me, I've been raised to learn everything, and do myself what I've learned.
Took me quite some time to respect people who live by the rule that one does not have to do what one is able to do.
One or the other has its own advantages.
I received new mains on friday, last xmas they blew up every appliance in the house with 400Vac.
Friday morning at 6am, I had a chat with the mains authority employees.
Told them I financed my MSc education at Delft-U by working at A'dam city center doors for $500 a weekend night, have a DNA wrapped-sheet for severe assault and battery, and am currently in a rather foul mood.
By Jove, excellent mains quality since, flawless.
Jolly good show, and not a nickel extra spent.
But I suggested something entirely different, really.
"Told them I financed my MSc education at Delft-U by working at A'dam city center doors for $500 a weekend night, have a DNA wrapped-sheet for severe assault and battery, and am currently in a rather foul mood."
My goodness, thank heavens for that little strip of water between us!
Single distinguishing feature between a clown and a cynic is the level of humor.
(though it could be a horrible cnt)
Never told you Fritz Deelman en die Diepsee Duikbol is my favorite book from adolescent years ?
(500 gross was 500 net, tax deductible pc, tax deductible everything)
Not all. There are rumors about a tiny village at the french atlantic coastline who resist.
- Member Areas
- The Lounge
