MOSFET Amplifier IRFP240/IRFP9240
HV23 or HV350
Hallo Apex, seeing that the HV23 and HV350 is basically the same and it is only the vas that differs, which is the preferred amp in terms of stability and sound ? How does one choose between them which one to build. 😕 Which one did builders preferred ? 🙂
Hay, this is my HV23 amp in stereo. The amp is tested at +-30VDC only because i don t have any 100v capacitor yet. It play very good ,the bias is set at 20mA for transistor. Also made PSU-7 for amp, it work but with minor problem.If I connect LED for DC protection indication ,the relay don t disconnect speaker. Without LED everything is OK.
Any sugestion how to fix that?
zoky2
zoky2
Nice work,
Apex, I replace 4k7 resistor with 6k8 resistor and now protection work. With 10k resistor the LED barely gloves so I use smaler resistor.
One picture from side to see backplate of heatsink.
zoky2
Sir Mile, i have made two HV23 amplifiers so far and am impressed with their performance. sound is great.
i also looked at Anthony Holton's AV800 and AV1000 amp schematics. as compared to the AV400, i observed that he added a pair of drivers and increased the number of irfp240/9240 outputs. i want to build another mosfet amplifier but my question is can the hv23 or hv350 be upgraded in a similar manner as Anthony's amplifiers? if yes, what upgrades would you recommend on the HV23/HV350?
regards.
regards.
VAS on HV23 work with 30mA bias and no need to add drivers in OS.
