2SK170BL
My guess is fake. Examine them with some magnification and you will most likely see the original imprint under the new 2sk170 one on some of them. Original ones can still be found with reasonable price from reputable sellers. I have bought fake ones also. If it sounds to good to be true you can bet it most likely is.
I managed to get 20 from a local source. I can get some more if its original. They all look from the same batch. I measured the idss and vgsoff. Most of them looked ok as per the datasheet idss vs vgsoff curves, could someone please eyeball these before I sink more money into it. Any other sure way of knowing if these are good. I dont have a curve tracer but I do have a scope.
Hi.I bought 200pcs of 2sk170bl from China.Are they genuine or fake?Here is pictures with flash and not flash.Taken with Galaxy note 2
Fakes.
Look at the 1 and 7 of "K170" totally different font. Look at my picture and compare to these Japanese real ones. Also the encapsulation of the plastic case is not as neat as with the real ones.
But it says made in Thailand, maybe different production line, different printing and cases ???
Don't think Toshiba would accept lower standards from a foreign plant, though.
Measure them for Yfs and you know it for sure. it's not that difficult to do.
See attached a circuit for curve tracing that everyone can build.
All you need is an accurate voltmeter.
Vary the value of the trimpot to get as many measurement points as you want.
Then plot Id vs Vgs.
There is no real alternative to verify devices than curve tracing.
Patrick
I could not find my DMM in my storehouse.But i checked 2 different types of genuine 2sk170bl with my Der EE de-5000 LCR meter.I measured GS capacitance at 1khz 10khz and 100khz
I checked about 10 of them and they all very similar to eachother.
Genuine japan made measurements
58pf 1khz
67pf 10khz
102pf 100khz
other genuine one ( i do not know the batch but it is from another batch
also measured very similar to this.
Fake Thailand made measurements
1144pf at 1khz
143pf at 10khz
51pf at 100khz
I think it is fake now.What is your opinions?
Hey Papa.Please explain it
58pf 1khz
67pf 10khz
102pf 100khz
1144pf at 1khz
143pf at 10khz
51pf at 100khz
