Umut,
Just measure the the current Idss (current flowing between power supply and drain). Short the G-S (i.e. Vgs = 0V), and apply Vds = 10V (without any resistor). You should get between 6-12 mA. All my toshiba JFETs are well within this range.
I finally found my multimeter and found the results
Its ma range is not working so i measured it by using 0,22ohm resistor
original japan ones have 2,3mv on resistors so it makes around 10,5ma
and thailand ones(maybe fake) They are around 2,8- 3,1mv so it makes more than 12ma
I also measured gs resistance with precision lcr meter
original one have 1Mohm resistance @ 1khz
118kOhm @10khz
and 20kOhm @100khz
fake one
10kOhm @ 1khz
11kOhm @10khz
13kOhm Q 100khz
118kOhm @10khz
and 20kOhm @100khz
fake one
10kOhm @ 1khz
11kOhm @10khz
13kOhm Q 100khz
That makes them V grade, not BL.
I also have genuine japan made V grade 2sk170 and its Gate to source resistance @1kHz also measures 1Mohm.Thailand made ones 10kOhm measurements makes them "fake grade" not V grade
Check the mA range fuse inside your meter. Probably blown.
Thank you .I had fixed it.Fake ones IDSS are between 14-15ma all.
If printed BL and measure 14-15mA there is no question, they are fake. Install high rapture capacity ceramic fuses if you ever use the meter on wall box building power. For safety.
Always look for "one" in genuine Toshiba 170 to be printed like l and for "seven" to have little curved leg. Thin gray-brownish etched print. Never have a letter in the back circle. Shallow small circle. Have a short _ scar on top middle where the face meets the back. Shiny legs and not totally flat. 14mm. Little copper showing where they enter the body sometimes.
very good description
- 2SK170BL
