Comparing LME49810, 49830 and 49811
811 is the mono version of 4702 with slight layout changes. 830 is specifically designed to drive mosfet output stages. 810 is beefed up version of 811 but having a classAB driver stage (811 has class A stage) to deliver extra current and has some extra features like baker clamp . You can consider that 810 is designed for hall and concert audio reproduction systems and 811 for hifi systems. You can find comments of Audioman54, a former National employee, in forum regarding these chips.
I did aural comparison with all the above chips and all of them sound different and I have read many of the audioman54 mark`s threads and replies. Agreed but my question is that if LM4702 can drive mosfets then can 811? can drive? or TI ripped off the higher Vbias feature in 811?
I'm not really a fan of mosfet transistor type.
Class A is not for me. I become a little bit "green".
In one of his articles, Nelson Pass discusses the paranoia of some purchasers of his amplifiers ... one supposedly could hear when it transitioned from Class A to Class AB.
Here are some LME49830 modules from China using the Toshiba MOSFETs:
Hi Mircea,
The board is very compact and and the components are neatly arrange. I have another question for you:
From the images available I did not see the component Rth NTC (thermistor) on the populated board (in the schematic is connected in parallel to potentioneter P1)
Is it an optional component?
Or it is foreseen for the thermal stablization of the output BJT bias current in case of use of BJTs without integrated diode for thermal track?
Best Regards,
Luigi
Hi Mircea,
Best Regards,
Luigi
Hi Luigi,
Yes, it is for thermal stablization.
Unfortunately the diode inside ThermalTrak transistor is nothing else then ultrafast diode (MUR120).
However, in this configuration I have a very good thermal equilibrium.
Mircea
Just another amplifier LME 49810 driving 4 pairs OT :D
Regards,Alex
