Slewmaster - CFA vs. VFA "Rumble"
The "SYMETRI" simple complimentary (Bimo) has many supporters. ROBUST topology.
"Symetri-Cascode" post #8349. You can run the .asc file to confirm ~ 25% lower THD with your models.
The "spookyamp" (leach amp) also uses complementary cascoded inputs, with a Hawksford VAS instead of the second complementary diff VAS used in Symetri. The BC5xxC transistors have a 4db noise figure. Cascoding the Symetri inputs also allows using ultra low (2db)noise JFETS as input transistors.
The "SYMETRI" should use high local negative feedback and use Miller compensation as small as possible. I tried it using double emitter output and PSU +-45VDC, and I pleased. Here the simulation result:
Phase Margin = 84
Gain Margin = 19
Slew Rate = 140
THD at 70W/8Ohm, 1kHz -> 0.004852%
THD at 70W/8Ohm, 20kHz -> 0.008530%
PSRR 1kHz -> 103
  • symetri cascode JFET.asc
update list
Nad look at post# 832,963,967.988,989,1005
Spooky #1247,1267,1292,1301
Gnome v1.3 #1455,1467,1485,1500,1516,1531,1538,1567
Symasui #1642,1671,1672,1673
Cfa ver.1.2 #1754,1756,1757,1784
Cfa v1.3 #2976
Wolverine ver1-c #3543,3564,3637,2279
Kypton C #4797,4765
Kypton V #5261,5282
Eyessee #5521
Kypton ND #6830,6850,6888
Bimo-Ostriper Symetry #8064,8066,8091
Infidel an unsuccessful IPS #5385
Ostriper schematic list look at post # 1
I hope this is a complete list and may be useful.
List with more details.
Nad (CFA)look at post# 832,963,967.988,989,1005
Spooky (VFA)#1247,1267,1292,1301
Gnome v1.3(CFA)#1455,1467,1485,1500,1516,1531,1538,1567
Symasui (VFA)#1642,1671,1672,1673
Cfa ver.1.2(CFA) #1754,1756,1757,1784
Cfa v1.3(CFA) #2976
Wolverine((VFA) ver1-c #3543,3564,3637,2279
Kypton C (CFA)#4797,4765
Kypton V(VFA) #5261,5282
Eyessee (CFA)#5521
Kypton ND(CFA) #6830,6850,6888
Bimo-Ostriper Symetry(VFA) #8064,8066,8091
Looking for more explanation ? see Ostriper detail list on post # 1
Cfa v1.3(CFA) #2976
Eyessee (CFA)#5521
THx for labeling which are CFA and VFA. Now can you please a minimum of specs -- add their SR and THD and power etc?
THx-RNMarsh
