Slewmaster - CFA vs. VFA "Rumble"
A small observation from today.
Few posts above I have posted pictures with simple mosfet OPS with only one pair of popular IRFP transistors soldered (82R gate stoppers), all was working really nice and stable.
Today I have soldered 3 pairs of irf540/9540 mosfets to the same OPS, it started to show some parasitic oscillation so I had to increase gate stoppers from 82R up to 330R (at 150R the oscillations were still present).
Now I am just wondering if It was caused by the two more pairs of OP transistors or just by the type of the transistor.
I will try to check it tomorrow.
It is not so simple as it looks like.
Beware, base stoppers had to be set as close from the chips as possible: I was shocked by your wires as I am with the long transistor's legs in your photo. Remember we are dealing there with something around 10MHz.
Esperado
But the version with the wires was performing really good. My problems have started afted I have soldered 3 pairs of irf transistors. Maybe the irfp transistors are less sensitive to parasitic oscillations.
I have placed the gate stoppers just by the transistor leg, the track on the pcb is no longer than 1-2mm.
I am wondering how to match correctly the gate resistors, just by the hardware measurements and tests on the bench ?
On the mosfet amplifiers they have values from 47R up to 470 or even 1k !
The most used is approx 220R.
cfa-vfa prototypes
Nad look at post# 832,963,967.988,989,1005
Spooky #1247,1267,1292,1301
Gnome v1.3 #1455,1467,1485,1500,1516,1531,1538,1567
Symasui #1642,1671,1672,1673
Cfa ver.1.2 #1754,1756,1757,1784
Cfa v1.3 #2976
Wolverine ver1-c #3543,3564,3637,2279
Kypton C #4797,4765
Kypton V #5261,5282
Eyessee #5521
Kypton ND #6830,6850,6888
Infidel an unsuccessful IPS #5385
Ostriper schematic list look at post # 1
I hope this is a complete list and may be useful.
Christophe,
I'm not so sure he wasn't interested in your proposal. The fact that we haven't seen anything from him for awhile is a bit troubling but I suspect he has had some family issues come up. I don't think anyone has heard from him? I just don't want him to disappear as NuwaveGuy did on the 02headphone thread. Let's give him some time and space before we start trying to chase him down.
The "SYMETRI" simple complimentary (Bimo) has many supporters. ROBUST topology.
"Symetri-Cascode" post #8349. You can run the .asc file to confirm ~ 25% lower THD with your models.
The "spookyamp" (leach amp) also uses complementary cascoded inputs, with a Hawksford VAS instead of the second complementary diff VAS used in Symetri. The BC5xxC transistors have a 4db noise figure. Cascoding the Symetri inputs also allows using ultra low (2db)noise JFETS as input transistors.
