Zenith console speaker wiring/removal
re 3 wires i have encountered this in other Zenith consoles some are indeed "bi-amped" others are merely parallel high passed through a capacitor but the wiring color scheme is consistently dark brown (- or ground) and beige/tan = low and drk brw and yellow = high.
That sounds great! Again, I'm a layman. No dilemma, just want to do it.
How do I make it be a regular speaker? I can place the 4 speakers in a box but the wiring....
Usually, my suggestion is to
1) mount the speakers frontally, so no hollow tube/cavity effect happens
(the back mount is for the grills to stay flat on the baffle, right ??! )
2) replace the double tweeter/w/horn with proper drivers, and mount them vertical, on axys ( with the woofer )
MAke two boxes ? easy
make two sounding boxes ?
but that's experimenting...
horn
Looking at the pics, I don't think it's that hard - there is only one pair of wires going to the amp, & there is a single cap poking out at the RH side of the horn... i.e simplest xover possible...
so, make your boxes, (~same size as existing cavity & with open back), transfer the speakers with the same wiring, & connect the lower pair of wires coming off the woofer to the speaker terminals you want to use... voila...
Should I cut the wire that leaves the woofer to the extension speak connection? Do I need to disconnect the wires from the tuner/amp?
Keep the back of the new boxes open?
ok great! so the lower pair of wires coming from the woofers can be cut and fed into a speaker terminal?
