Moode Audio Player for Raspberry Pi
Small town near Detroit, Michigan.
Unable to repro "config.txt not being updated with dtoverlay= line" issue. I tested with a Pi-2B, HifiBerry DAC+ and Moode 2.0 download image.
After booting up I set I2S audio device to HifiBerry DAC+ then reboot. Config.txt had dtoverlay=hifiberry-dacplus line and Radio station played fine.
Tim
Tim
I don't know why it happened then - it wasn't an isolated occurrence.
I'll have another go. Is it alright to use the version on the AWS bucket?
I'm having some rather basic problems getting connected, and am hoping for a little help.
I've got a RPi2 booted with 2.0. It shows up on my IP scanner, once as Moode and another as RPi. Plugged into a router, I can access it from the Moode.local in the browser, but when I go to prefs and plug in my wireless pw, after I hit submit, I can't get it to refresh and the browser refuses to load again for some period of time. I get frustrated, try again the next night, and get the same behavior. Plugging in assigned IP addresses gets no better results.
Any idea what I'm doing wrong, or what I should be looking at to troubleshoot? Tim, I do appreciate all the hard work and can't wait to get this thing into a workable state.
Send email to tim at moodeaudio dot org and ill help troubleshoot. The symptoms suggest failure to join wifi network for some reason.
Tim
Here are the steps I use to set up a WiFi connection (from the readme).
3. CONFIGURE FOR WIFI CONNECTION
a) power off (from Menu/Turn off)
b) insert wifi dongle
c) power up (leave eth cable connected!)
d) "http://moode"
e) Menu, Configure, Network
f) configure a wifi connection (can take ~ 60 seconds to complete)
g) power off, unplug eth cable, power up
Tim
Just a brief update on release 2.1 🙂
2.1 Release 2015-07-DD
New features
- NEW: Expand SD Card storage
- NEW: SDCARD music folder in Browse panel
- NEW: Button for easy toggle between knobs and album art on small screens
- NEW:
Media
- NEW: Soma FM - Fluid: Drown in the electronic sound of instrumental hiphop, future soul and liquid trap.
- NEW: Soma FM - Left Coast 70s: Mellow album rock from the Seventies. Yacht friendly.
- NEW: Soma FM - ThistleRadio: Exploring music from Celtic roots and branches
- NEW:
Updates
- UPD: Add SDCARD, USB2/3/4 samba share names
- UPD: Disable volume knob when MPD volume control set to disabled
- UPD: Radio station name space based on station file name and URL
- UPD: Add USB device name "Audio" to MPD config friendly name logic
- UPD: Add CM6631A USB/SPDIF converter to audio device DB
- UPD: Add NAD D 3020 Integrated Amp to audio device db
- UPD: Add chip spec for Hifiberry Digi+ in audio device DB
- UPD: Shovel & broom to remove some legacy code/files
- UPD:
Bug fixes
- FIX: Playback controls visible on config pages when on small screen
- FIX: Song file w/o title tag incorrectly labled as "Streaming source"
- FIX:
Tim
Hello, I've just signed in to thank you for the version 2 of MoOde.
Long time volumio/rune user. IQ Audio PiDAC+ owner.
Some time ago I tried an old 1.x release and I wasn't satisfied, so I forgot about it.
MoOde 2.0 instead is great as it includes out of the box many features long time requested.
On the top of my mind after a quick test it's missing:
- last.fm scrobbling, direct config from UI
- buttons to quickly "add, replace and play" a whole album from the library.
As now there's only "add" for albums. (songs have add, add+play, add+replace+play)
Robert
Robert
Hi Robert,
Thanks for the nice compliment!
I'll add your feature items to my to-do list. I might be able to squeeze in the "add, replace and play" menu pick in release 2.1.
Moodeaudio.org
Moode on Twitter
Tim
mDNS as implemented by avahi uses the .local designation
I have a bunch of routers - Cisco's, DD-WRT, etc. - none resolves a url without a suffix.
Maybe it's a Windows thing? I will have to fire up something running that awful POS 🙂
EDIT: Actually, I suspect it might be a Bonjour thing - I use Mac's almost entirely for desktop. Bonjour doesn't strictly follow zeroconf/Avahi standards.
And... I just remembered that I don't usually change the 'zeroconf' setting - so, there's a bunch of stuff for me to test - I have a lot of bonjour/zeroconf sniffers (I use it a lot on my embedded MCU projects)
Using OSX for most things these days 🙂 but "http://moode" also resolves from my Win7 machines and IOS devices. I've never needed to use .local for any of my hosts.
Router is RT-N66U running an older Merlin firmware. He made some nice enhancements to dnsmasq for the ASUS routers. If the mood strikes (no pun intended) I'll capture a dns query with Wireshark to see whats going on.
Tim
