10F/8424 & RS225-8 FAST / WAW Ref Monitor
It's been about 10 to 12 days for the orders from Aliexpress. They have a very good policy with DOA's or orders that don't arrive within 3 weeks. You keep it for no charge. They have an unbelievable ability to ship for free.
I haven't seen the equivalent Meanwell with dual rail and 50v at 400watts to 500watts. If you see something please send link.
These IRS2092 are made by Yuan Jing I think. It doesn't say but blue black color scheme is characteristic.
The ampmodules are on Ebay too, little cheaper even.
Ebay customerservice does respond when you ask a question. Ali after a full refund turned evil and cost me around $50 manages to ignore all 45 tickets I made last 1.5 year asking them about their full refund policy that ended being more expensive than no refund. (after deducting a fee for unjust reason they managed to wire money back to me in a manner that was more expensive than the amount they transfered to me, with receiver paying costs for very expensive money transfer. The refund was asked for by seller that couldn't deliver ampboard)
Maybe my experience with Ali was dependent on the seller. It was tough getting a shopping identity established though on Ali - they kept canceling my orders for a while because they could not verify my identity for some reason. I think it was because they entered an incorrect zip code. I could not figure out until I called my CC company and they said Ali kept trying to put an order through with a bad zip code.
Sound Clips Comparing TPA3116D2 amp with TDA7492 Amp
Sound clips and measurements of the sound quality from a TPA3116 amp wit and without the new LC-filter Zobel mod, and TDA7492 amp (which has the built in Zobel circuit) as suggested by StanleyBurbick.
More technical details here:
http://www.diyaudio.com/forums/class-d/237086-tpa3116d2-amp-727.html#post4357821
Sound Clips here:
http://www.diyaudio.com/forums/class-d/237086-tpa3116d2-amp-727.html#post4357835
Blue is the TPA3116 and grey is the TDA7492:
Here is the ne so-called LC filter Zobel mod (tiny SMT 10R and 0.1uF in series connecting the two legs of the input pins to the inductors):
This 53v dual rail PS is available at PE for $20 free shipping for orders of $100 or more. It can sustain 4.1 amps for 5min which makes it a real contender as a supply for the IRS2092.
For europe PE might also be unatractive, although the PSU still looks cheap to me with added costs, UPS also bills you tax at delivery or by mail if they know you, it isn't a chinese company 🙂
Shipping Options
UPS - Worldwide Expedited (Excludes Duties/Tax)6/23/2015 23:30:00
$44.23​
UPS Worldwide Saver (Excludes Duties/Tax)6/19/2015 23:30:00
$56.51​
Harsch Transient Perfect XO
This XO topology employing 4th order Bessel low pass for the woofer and 2nd order Butterworth high pass for the tweeter proposed by S. Harsch appears to be very interesting in its ability to produce an almost linear phase XO for transient perfect reproduction. The advantage is the steep 4th order on the woofer low pass that can suppress the cone break up on the woofer that causes the sound to not be "clean". I will try this soon and if it works, could be very cool. Thanks to Phaseaccurate for the tip!
http://petoindominique.fr/pdf/phase.pdf
If you can make out the French (easy since the technical stuff is universal) it says this:
1. Choose XO freq fc
2. Set Butterworth 4th order low pass for woofer at fc
3. Set Bessel 2nd orde r high pass on tweeter at fc
4. Set delay equal to half cycle of fc
5. Invert polarity (on which? Or does pas mean do not?)
Sim of Harsch XO using PCD
Since I had the FRD and ZMA files from my 10F/RS225 monitor already (SATX pulled them from manufacturer website for RS225 and from my measurement for 10F), I was able to put this into Jeff Bagby's excellent simulator program (Passive Crossover Designer or PCD) to test out the Samuel Harsch XO concept. I decided to use an electrical XO frequency fc=400Hz (requires a delay of 1.25ms on tweeter). I had to apply a few very minor PEQ's to flatten things (shown below), but the overall sim looks very promising.
Here are the PEQ's used:
Code:
Woofer: -2.5dB @300Hz, Q=1
Mid/Tweeter: -1dB @1000Hz, Q=1, -1.8dB @10kHz, Q=1  and overall padding of -6.0dB
Crossover filter settings per Harsch recommendation:
Woofer is Low Pass Butterworth 4th order at 400Hz
Mid/Tweeter is High Pass Bessel 2nd order at 400Hz with 1.25ms delay relative to woofer.
Here is the resulting modeled XO response:
494976d1437582087-10f-8424-rs225-8-fast-ref-monitor-harsch-400hz-10f-rs225-xo-pcd-sim.png
Here is the predicted group delay (notice the relatively flat GD through the XO region):
494977d1437582087-10f-8424-rs225-8-fast-ref-monitor-harsch-400hz-10f-rs225-gd-pcd-sim.png
Next step is to try this in real life...
Although electrical xo freq was 400Hz, the acoustical xo appears to be about 550Hz. So the natural response of the speakers may call for asymmetric xo frequencies. This may help reduce the dip at the xo region because it is too wide now.
That's pretty cool. I tend to like asymmetrical crossovers for pro type speakers or wherever a steeper slop is required, and often suspected they could be "quasi optimal" transient pretty good if done well, based on what i heard. Nice to see some more extensive data.
One thing that always gets me is that the textbook slopes of these more esoteric XO's are generally hard to achieve in reality as the response of the driver, the enclosure, etc modify it. So just picking an electrical 4th order Butterworth for example, is only half the story. Generally, I have a hard time achieving true 6dB/oct fall off for a 1st order. Until the acoustic (measured) XO slopes match the textbook example, the sim will be off and you get a different behavior. Then you have to try to use some mile PEQ'ing to shape the response to the textbook shape.
