Quanghao, you still offer chassis for these dacs?
ok, but i need shipng to you!
thanks
Stupid question, where can I order the Toslink and coax receiver that fit on the dac?
ok,
1 x Toslink
1 x RCA (coax)
and shipng by carrier envelope
all 25 usd
thanks
Sent Dac
Hi All,
I update list sent Dac until date 16 May 2015 below, Please check and pm:
1. Kanan_s, number tracking 520825694, sent on date 27 Mar and receive 2 Apr 2015.
2. Anton Mehl, number tracking 520825685, sent on date 27 Mar and receive 30 Mar 2015.
3. Bamarek, number tracking 520825822, sent on date 01 Apr and receive 8 Apr 2015.
4. Ankltam, number tracking 520825819, sent on date 01 Apr and receive 8 Apr 2015.
5. Hego, number tracking 520825836, sent on date 01 Apr and receive 9 May 2015.
6. Jazzbear, number tracking 520825924, sent on date 04 Apr and receive 7 Apr 2015.
7. SebastianL, number tracking 520825955, sent on date 04 Apr and receive 10 Apr 2015.
8.Roboto, number tracking 520825941, sent on date 04 Apr and receive 8 Apr 2015.
9. Atterbud, number tracking 520825938, sent on date 04 Apr and receive 13 Apr 2015.
10. Biblos, number tracking CP120148895VN, sent on date 11 Apr 2015.
11. Sanghun Lee, number tracking 520826108, sent on date 14 Apr and receive 17 Apr 2015.
12. Rifilex, number tracking 520826111, sent on date 14 Apr and receive 27 Apr 2015.
13. Feriandas, number tracking 520826139, sent on date 15 Apr and receive 21 Apr 2015.
14. Gianluca Andreani, number tracking 520826289, sent on date 20 Apr and receive 28 Apr 2015.
15. Artur5, number tracking 520826261, sent on date 20 Apr and receive 23 Apr 2015.
16. Edgar, number tracking 520826275, sent on date 20 Apr and receive 28 Apr 2015.
17. Studiosynx, number tracking 520826598, sent on date 21 Apr and receive 24 Apr 2015.
18. Nerkap, number tracking 520826669, sent on date 27 Apr and receive 29 Apr 2015.
19. Oydes, number tracking 520826672, sent on date 27 Apr and receive 30 Apr 2015.
20. Alessandro sent on date 04 May 2015 and receive from my friend in Italy.
21. Szczmire, number tracking 520827616, sent on date 05 May and received
22. Koeniwo, number tracking 520827633, sent on date 06 May and received
Suggest you named below, please pay the remaining 50%, in case you do not have contact, I will transfer Dac for others, and a refund for you.
1. Tim St Ruth
2. Reins
3. Rolandong
4. Vladimir Bazelkov
5. Debianx.
Please contact me.
Thanks!
Quanghao.
Hi All,
1. Tim St Ruth
2. Reins
3. Rolandong
5. Debianx.
Please contact me.
Thanks!
Quanghao.
How much the chassis for the old display? Would take both together then
Ok i see now, the chassis for V1 DAC, now i not have it!
only for V2
thanks
quanghao
Okay been reading many informations but didnt find anything... So I have to ask again here...
Was feeding the Dac these days via toslink... There I had repeatedly glitches in the sound. Where does this come from ?
Do I have to update firmware? As far as I know I got the firmware that was onbard when it was shipped. Second question : What do I need then to do the upload?
DAC version 1 - problem on optical input
Do you have this problem only on optical input ?
Do you see some lock lost on display or you only ear click on loudspeakers ?
The optical receiver is a standard type and there are no components on the signal path from optical receiver to dac chip.
The firmware cannot be the cause of this problem.
Hi
I have seen similar issues and also unlocks with coaxial input.
The issue here was some of jumpers that connect the dac chip to the voltages supplies was having to much resistance. They should be 0ohm but i did measure a low voltagedrop over the jumpers. You can try to solder the jumper pins together if this is the case.
Br
Caad
Hi
Br
Caad
Can you explain better what you suggest and which are these 0ohm resistors ?
Hi
The Jumpers between the shunt Regulators and the ES9018.
I have seen bad connections in the these Jumpers.
You can unmount the jumpers and solder the 2 pins of the Headers instead of using the Jumpers.
Please see the dedicated Jumpers in the pic.
Please note: I have only seen this topic on the Version 1 DAC (The DAC with 16*2 Display).
Br
CAAD
Will try later....
Strange is, the first few minutes there is no glitches...
After 5-10 minutes it starts....
Hmmm could it be possible that the digi amp I'm using sometimes distorts there little bit?
what??
can you tell me now?
Hmmm changed the toslink receiver and let it burn in... Since two days no glitches
Great!!
Let hope it works.
If the glitches comes back then you can try to solder the jumper pins as described.
Br
Caad
But think gave some grounding issues...
When I switched off the fan today the dac stopped playing for a second
Sent from my Mi 4i using Tapatalk
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
