Class D Amp with LM566, LM393 and 2XIRF530
Sir Mile,
I do think this one is much better, I was so eager to try this lay-out but I am currently living in a place where Laserjet printer is so elusive 🙁 and if you can find one, shop attendant refuses to use glossy paper. :whazzat: :headbash: and I don't own one 😀
I will share the lay-out, others may find it useful. PCB size is 55X145mm almost the same width as the original D200.2 pcb. If this design is a success I will integrate the XLR pre-amp. 😉
  • D200v2_component.pdf
  • D200v2_etching.pdf
    D200v2_etching.pdf
Sir Mile,
Nice work, thank you.
