Live Lab Hangout #1.1 Posted
In the absence of Sea Ranch secrets here are the circuits swimming around my head these days. Gathering parts and planning layouts...
That SEPP circuit is straight from a Tokin app note.
The other circuit was lifted from a DeLite thread and lightly modified. I like the bias portion, just need to wire it so that a scratchy or open pot wont cook the SIT.
Hello all. I have build lamp amp using 2sk182. Results are very exciting... Power supply are two PS in parallel and 30V, one 500W 150V bulb and 8 ohm resistor.
Sorry, I had in bad state my Rload. With 7ohm load in good conditions, power output low to 4 Watt into 8 ohm (see photo). I have calculate Zout to 4.2 ohm.
I want to increase voltage of PS to try get greater power output.
