BA2000 is just idea, not tested and no pcb design.
Dear Sir,
what is your impression about the idea? bcoz u r the right person to judge, could it b build with one pair for testing, what do u suggest?
If u have any other such design tested which u feel free to share pls know me.
Thank U so much,
Pranay 🙂
good night.
At the request of some friends, I share APEX simulation BA-1200
Apex BA 1200 - Download - 4shared
hi apex sir, how is this simulation?
load 4 ohm.
55V output is 750W 4R load
Power Amplifier CAPACITORS !
Hello Audio fanatics, if someone need 34000 mFarad 55V DC capacitors SANGAMD made in U.S.A for multi-channel power amplifier, or for lowrail voltage stepper power suplly there is the choice for adequate price.(30 years old, little used, but rare thing to find today,...
https://drive.google.com/file/d/0Bz9Jc002TU8kUm1DdkJoZFpzcU0/view?usp=sharing
hi apex sir,
i increase the 33k resistor to 43k and now power goes up, 900watts,
any suggestions?
You can reach the 900W output power if You keep the 33kohm resistor, and increase the input level....
The original desing has the gain, about 34, so You need approx 1,85Veff for 1000W/4ohm.
Sajti
hi apex sir,
any suggestions?
You just increase gain not power, you can find maximum power with increase input level to the clip, output voltage without clip give you maximum output power.
nothing change, only 550watts/4ohm
There is the XFG-1 on Your picture. That gives the input of the amplifier, I guess. Increase the output level of this generator. It looks now 1Vpeak. Try to set 1.5Vpeak, and check the output power...
Sajti
sajti, how many milliampere per output u recommend?
if You mean the bias, I wuold not go over 20-30mA.
Sajti
is it the bias is high in the image i posted.
685ma output bias per transistor,
685mA makes smoke in very short time....
Sajti
increase input to 1.3v,
now around 1000watts.
What is cliping level on your simulation?
P { margin-bottom: 0.21cm; } Hi Mile, can I run this topology with this step driver, 120-60-0-60-120 VDC, and the proper
– 15VDC + 15VDC power suply, to drive 4 R load. Should I change something ?
Pozdrav.
Pozdrav.
- 1000W Simple PA Amplifier
