Build thread - building the Subbu DAC V3 SE
Next step anodizing.
Gold,gray or black can't make up my mind.
Beautifull box ! Wow ! Any cheap GB planned ? Aluminium is light 🙂
In your shoes I will put a connector at each side of the partition wall instead a hole to allow even more EMC isolation ? two tunnels for AC wires with a widther box if JG buffer used (need to be feeded by a separate supply) : to allow an AC plug at the bottom of the box but separated by a partition wall from the DAC board aera !
Will make the box a little bigger despite the big thick of the partition wall to move away more the PS unit from the pcb dac unit ? For a second PS (JG buffer) : PS compartiment splitted in two to isolate the traffos from each other ?).
And we will ask 😀 to adapt the new PS of Jean-Paul for a symetric +/- 15 V for the Joachim Gerrard buffer ! Nah, it will be only + 5V 😛
And you can see Gary posted on the first page a link to Korben69 aka Phil voltages measurements picture on all the pins !
So it's easy to find if you reg(s) is broken, shorted, etc ! Look at the picture !
If one of the chip has a bad voltage measurement but the regs show an acurate voltage, you have to carefully resolder the chips pins with a magnifying glass and some flux ! Most of the time it is the Wolfson's chip which has a bad contact !
started soldering Subbu DAC. When I soldered U3 mic I got the impression of a flash
while soldering the three side feet. Do you think I damaged the mic?
northernsky
finally I completed DAC soldering and made the preliminary test, measuring VDC at L3-L6 without these inductors soldered.
I think the test is OK, but please give a confirmation, since I am not expert.
On one side of inductors I measured the expected VDC and on the other side I got obviously 0VDC as in the rest of the circuit. But only for L5 I get the measurement as in the picture in post #1 describing the test; for the others I get 3.2 or 3.6VDC on the reversed pin. But I assume is an error in the picture,
am I right?
Thank you
Northernsky
You're welcome Northernsky 😉
Please refer to Post #911 in this thread.
You'll find some usefull measures.
As you haven't populated L3/4/5/6, you can't measure further 🙂
BTW, 50MHz XO isn't fed, same comment for C17/22/13/8.
So, please check again your voltages on Tantalum C27/26/15/16.
Please confirm you've measured positive side of the caps (+).
If previous request is correct, then I suspect U3 (MIC5205 3.3V) to be faulty.
Check U3 pins 4 (Gnd) & 5 (Vout) values, according to attached pic.
Phil
