Tell us more about the dac . This a fine setup.
It's all here:
http://www.diyaudio.com/forums/digi...dac-pcm1794-waveio-usb-input.html#post3252373
It sounds excellent....😀
Walter
Hi together,
this is my D1 Clone, thanks to Papa! This board is from Spencer, it took some time to go to the "last" housing (years!?). 😀
Black Gates, Vishay Z-Foil for I/V and som little things more. Now it ist time to play with the PCM 63P K2 ore Y ore something and some kind of receiver are here. Let's play!
You've taken great care to shed the heat and I applaud the unconventional format! Bravo!
I'm a woodwoker coming to this building of things metal. I miss the warmth of wood objects in my room. Yet, one woodworker to another, try some angle aluminum for reinforcement if nothing else. Woodworking tools work fine on T5 & T6 series aluminum 🙂 with it you can get even better. 😉
Happy listening and congratulations on a successful build! 😀
Thanks, I had an idea that started with the heatsinks and it was just a matter of trying implement it some how. They run about 21F above ambiant, and I'm biasing at .69V for now.
Just wondering, what would I need to reinforce with angle aluminum? I used my table saw to cut the copper bar it worked quite well. The copper was a pain to drill though... speed, feed and Tap Magic.
Thanks again!
erpiii,
OF course I am speculating as I don't know your whole plan but with the trouble you went to to keep air around the heat sinks the solid wood sides would be an impediment to air flow. Thus I figured that you figured solid sides would be necessary for strength.
Copper is kinda gummy for drill and tap, gotta use a lot of lube and clean the tap every turn or so. Sure is pretty though 🙂
How do you like the sound? 🙂
Finnished my new CD -shelf... Yes, yes.. I know this ain't an amp, but I feel you guys are my pals and felt like shearing this with you. 😀 And actualy there doesn't seen to be a forum for woodwook here..?
I think it look quite nice. 🙂
You can find a couple of pics here: http://www.diyaudio.com/forums/everything-else/269561-cd-shelf-finnished.html#post4219339
Another dutch Aleph-J ready, finally !
Finally the Aleph-J is finished.
She played for a few weeks together with the BZLS, very nice
Nick
Here some pictures :
Nick
Hi together,
very nice build, typical german !!!
625VA transformer?
No, 500VA. Found it in the "koopjes-hoek"
Wonderful! Congratulatons on a beautiful construction!
Sounds good, doesn't it? 😀 😀 😀
Yes, it does !!! Balanced even better.
Love the all DIY serviceable part inside sign on the back . Where you get the heat sinks ?Finally the Aleph-J is finished.
Nick
A look inside .
Beauty amplifier , diy solid built
Congratulations Karajak !
Greetings 🙂
- Pictures of your diy Pass amplifier
