100W Ultimate Fidelity Amplifier
Apex A9 irfp240/irfp9240
credits PCB Sonal kunal
Mods Thiago
not tested
By the way, last weeks I have built the A9, A14, A17 and A33.
My Hitlist is:
- A14
- A9
- A17
- A33
But that's just my subjective opinion and only based on listening music. Now a lot of new amplifiers were built. I'm curious how you see it. Any experiences? What is your rating?
regards Olaf
You must use multi turn potentiometer and for correct bias adjust 680 ohm resistor will be change to 1 Kohm value . Today I have tested A33 amplifier with +/-50V voltage rails and playing nice .Only first two MJE340 and MJE350 are warm ,so I attached a small heat sink .🙂
Regards,Alex
Instead of 680ohm+200ohm multiturn , I use 330 ohm and 1k ohm multiturn.
I had many of 1k multiturn ...
Thanks , Laur
Hi Alex,
Please explain further. What value do you use for P1 and what value do you use for P2? May I assume the 680R you refer to is the one in the VBE multiplier?
Thanks, Terry
Hi Terry,
I used 200 ohm MT and 1K ohm resistor for bias .... and 4K7 MT for offset adjust.
Right ,680 ohm resistor it's from the VBE multiplier
Regards,Alex
