Slewmaster - CFA vs. VFA "Rumble"
Back to work .... Kypton- ND
Just finished my 4th new design ---> Kypton -ND.
"Kypton -C" needed a "brother" 😀 ....
The old NAD ... with -
- CCS/servo (not in audio path).
- Super hawksford/baxandall VAS.
- Cascode on 2'nd stage.
- Q1/5 and Q2/6 fully negate thermally (just leaving the negative LED CCS's).
-also .... "clips like a tube" !!
(schema below 1)
-Upcoming ... the bootstrap amp , simetri , this Kypton , and I have permission
to do ONaudio's " SYMEF.
SYMEF = a blameless/LIN with a mirrored cascoded symmetrical drive VAS. The
level shifter approach is different. (symef concept- below 2)
Edit-( below 3 )... Kypton-ND does the "overload thing" better than "C".
plot - super pair base (top) , clamped super-pair emitters (middle) , and tube-like
rounded overload (bottom). 15ppm and nV offset , as well.
OS
My reservations about the original "VSSA" are gone ... as the Kypton-C solves
any over current/saturation issues and has "acceptable" PSSR.
Ultimately , with my sub handling the bass .... Kypton-C might be my permanent choice.
OS
So you've finally found out that the subtraction on a single device is the way to go. What you have here is VSSA principle with enhanced VAS, but still with wrong feedback R-C configuration, the reason for weak bass. Just to inform you VSSA can even do better, ie. her bigger brother is the answer.
In my controlled situation , I'll compare the "ND".
As far as the "wrong R/C" ... do you mean more current and a bigger DC cap?
Simulation does show this gives lower LF THD , but would this be audible ?
I'm about to make the "transistion" Kypton-ND ,will be mixed SMD/through-hole.
OS
Hardcore CFA tests - kypton-ND
(below 1) - the PSRR is acceptable for a CFA.
Improvements in the power supply (dual mono or variants) will
make for good SQ.
(Below 2) better gain margin and higher UGLF than most.
(below 3) absolutely perfect rail to rail squarewaves with 270V/us slew.
As I said , thermally ... less than 5% VAS Ic variation (0-50C)
The infamous "Infidel" was the source of this perfection.
The layout and performance should actually be as good (or better in some aspects) ,
than the kypton C. NO DC caps , single current FB path , single simple compensation path.
Oh , better 1st/2nd stage BCxxx devices .... (high 500Hfe)
Thimios built 2 versions of the old "NAD" - I know it performs.
This performs X2 !! 🙂
OS
The bigger transformers don't cost much more and since I build mono blocks space isn't an issue. Two channels of 5 output pair slew monsters are running at about 83 volt rails driving a pair of 15" open baffle woofers each. Lots of eq to get the lower bass so they seem to like lots of power.
OS bought dual 1000VA transformers for his Slewmaster? Amazing!
Nope , Brother Valery got me just 1 - 1KVA 50-0-50 triad (20A).
Triad Magnetics Product Specs
Split the 16ga secondaries into 2-18ga ... then to 2-35A bridges. This connects
to 4 X 22Kuf capacitor banks @ 73V rails.
Might be enough for china breaking 😀 .
EvanC's "real man's" trafo is really a 400VA , and it gives 65V rails for the sub.
Just a humble 2.1 home theater/music system.
PS - I had to re-machine the main amps to put the outputs in the
middle - my only major screw-up. (below)
Off - center more than 25% horizontal makes the end output pair much higher
bias. I'm under 10% now ... 🙂
OS
OS
Very cool, Brother Pete :up:
Interesting experience with off-center - good to know 😉
