Ultra-high performance, yet rather simple - hybrid and more!
Hi Terry, I will check everything once again and let you know.
Valery
Terry, I ran all required simulations - here are the amendments for JFET input version.
Basically, three values need to be corrected - R5, R10 and C9.
Please test IPS standalone first, as usual.
Valery
There are many offers on e-bay - from China, Hong-Kong and Taiwan - but I'm absolutely not sure how they are manufactured (looks like Toshiba has stopped producing them some time ago).
In the modern product line, they've got only two dual-fets (2SK2145 and 2SK3320, SMD-packaged), both are very good for audio applications, but in both packages they've got sources connected internally - no way to use degeneration in differential pair:
>Modern Toshiba JFETs<
The world is not perfect 😀
Thimios, I will send you some 2Sk117 ones together with CFA-CFPx2 PCBs as soon as they arrive - easy to buy here 😉
Good news ,waiting for this! I don't like fake parts from e-bay🙂
Where can the 2SK389 be purchased? That is the jfet that Dado required for the TT amp I just built but I couldn't find them anywhere. I had to use 2SK170s as replacements. I had to twist the legs to make them work.
Terry, my TT amp does not use 2SK389BL, this is Toshiba plastic case, but LSK389B from Linear Systems in TO71 metal case and Google shoved this link where to buy: Trendsetter Electronics Online Store - Parts, Components and Electronics and I think it's worth the price.
BRDamir
Valery
I remember seeing recommended changes for BJT inputs but I've reread the whole thread a couple times and can't seem to find them. Will values in the first post work?
I have re-checked the original datasheets - Damir, you are actually right, thank you for clarification. K170 may typically have slightly lower noise. However, capacitances (Ciss, Crss) are twice as much, although it's not really a problem here.
Well, must be ok. Sam - try it, it's really very close.
