Super Regulator
Part 4 -- Gary is very meticulous -- if you've followed his writing. There's a trade-off with an E-Core or torroid. While, as he mentions, the E-Core is limited bandwidth and doesn't transmit line noise, it's also likely to have higher leakage inductance which may result in some diode ringing.
He also seems to be a "belt and suspenders" guy -- as he uses a bifilar choke on the power supply, which should knock down EMI
... [the E-core transformer] is also likely to have higher leakage inductance which may result in some diode ringing.
Yes. Fortunately this is easy to eradicate. All you need to do is measure the secondary leakage inductance*, plug it into Hagerman's formula, and install a snubber
  • Rsnub = (1 / (2 * Zeta)) * sqrt(Lleak / Ctot)
Voila, diode-induced transformer ringing is perfectly annihilated, to whatever damping factor Zeta you prefer. Hagerman suggests Zeta=0.5; myself, I prefer Zeta=1. Either way the transformer secondary ringing is stopped completely; dead. The cost is modest: (2 capacitors + 1 resistor) per secondary.
Attached are some measurements made by diyAudio member DNi and posted to a thread in the Power Supplies forum of DIYA. They show an unsnubbed secondary winding, and then three different snubbers with three different damping factors (Zeta). The scope is triggered at the instant when the rectifier diode cuts off.
*This turns out to be rather easy (!).
_
Yikes, one of those images was a miniature "thumbnail" instead of fullsize. Sorry about that! Here's hoping all four come out correct THIS time:
I've not done any of the background reading, I was hoping that people who had done over the years would present a perfected version.
From this thread it's seems that the 2000 version, as in the Linear Audio article had the additional three pin regulator preceding it, jackinnj posted that that harmed the low out put Z, this latest design therefore would be the 1995 version, but with the sensing chip after the pass transistor from teh 2000 version, but with a developed load sensing circuit added to the schematic by Jan in 2014?
Is that about correct?
No, the load sensing was fully developed in the 95 article
Why don't you do some reading and form your own opinion?
Must faster and reliable than sifting through confusing and conflicting posts 🙂
Jan
In the formula you refer to LLeak is measured from each secondary with primary shorted: correct?
D
I recommend you read Hagerman's snubber paper and also the Quasimodo snubber-design paper.
The most thorough exposition I've ever seen, is in Christophe Basso's textbook, excerpt below. However Basso is concerned with high frequency switching power supplies and the transformers used in HFSMPS. Plain ordinary 50Hz/60Hz mains transformers, probably do not require the same level of precision; they operate on a very leisurely timescale (milliseconds!) so there are no uncomfortable trade-offs between power and noise-reduction.
Basso is careful to isolate and extract ONLY the secondary leakage inductance; however it may be preferable to use the effective secondary leakage inductance in snubber designs, with the primary's leakage inductance reflected (thru the square of the turns ratio) into the secondary. A few SPICE simulations may help you decide which one you prefer.
The first way to skin the cat is (i) measure Lleak and Ctot; (ii) select a desired Zeta; (iii) calculate Rsnub using mathematics.
The second way to skin the cat is (a) connect the actual transformer, rectifier, and snubber together in a working circuit; (b) electrically stimulate the circuit and observe the oscillatory ringing on a scope; (c) adjust Rsnub potentiometer until ringing disappears. This is the "no-math" approach.
_
I completed the regulators today, but I have some troubles getting the right voltage.
The target is 5V, so I have the 2.5V reference. I am using the AD825. I get 7.2 V out. The reference is correctly 2.5 and the led is on. If I decrease R6, there is no effect.
Any hint ?
Thanks,
Davide
I saw that, but I was not sure that it would still apply with new opamps, as in Jan's article, only the voltage reference mod was highlighted.
Anyway, I modified what in the current board are R2 from 10k to 5k and R5 from 4.99k to 2.5k (I actually soldered one more resistor of the same value on top of the existing one) but I still get the same results.
I think the AD817 should be more suitable than AD797 recommended in the article: is it correct ?
Thanks,
Davide
Thanks,
Davide
The ratio of R5/R3 sets the output voltage. R5 should remain 1K. Vout will be Vref*(1+ (R5/R3)). (I don't know why Jan put the parenthesis around R5 in the article.)
Thank you for pointing it out, I did not notice it. With the 4148 in the correct direction I now get 2.5V at the output. I think that I just have to change the op amp. By the way, the board works perfectly for 14v.
Thanks,
Davide
Sent from my iPhone using Tapatalk
