FAST with TL?
Dave: I can still move the bass driver down the line as the driver holes are not pre-drilled. However, I wonder if the sound will be more uniform if they are closer together?
attachment.php
36 square feet of 24mm BB ply sawed to measurements for 100 dollars. Not a bad price, at least by Finlands standards 😀
It's a very good price. 🙂
How far you can slide the woofer down the line depends mostly on your crossover point. As this is a FAST, and the crossover will be low, there is some wiggle room. The general rule of thumb is 1/3 wavelength, though some will say 1/2wl, and 1/4wl is better if feasible. Basically it will lobe if they are too far away. This must be balance against the increased smoothness you will achieve with an offset driver.
I simulated the 3 options. To my untrained eye, the driver 1/5 down the line would seem best in this application. The 1/3 down the line is too low considering the distance from FR driver unless I lower the XO point.
Given the reality of the enclosure and the fact that it isn't a hypothetical tapered cylinder with a perfect flat end, I think three decimal places of precision is a bit optimistic...
Anyhow, if it were mine, I would probably choose the ~1/3L placement for the woofer over closer placement to the TC9FD. Having a big null at ~130-200Hz. can really take away from the subjective weight and enjoyability of the music, and an offset driver is the easiest way to get rid of it. OTOH, I and many others built successful end loaded TL before accurate sims were available. With careful attention to stuffing, etc, problems can be minimized. You may want to try in 1/5L placement in your software also, as a compromise. (10"/25.4cm offset)
EDIT: Oh, you beat me to it. Yeah, 1/5 looks pretty good.
GM makes a good point about floor bounce and eigenmodes. These are very real effects and should be considered.
I would pick the 1/3 option for the increased bandwidth. You don't want the XO to be below 200Hz - it starts taxing the TC9FD on excursion and reduces the midrange clarity. Also for reasons GregB gave about weight of mid bass in the 80 to 200Hz region is where a lot of impact comes from.
Seems like I have a choice between rock and a hard place. What would happen if I used two bass drivers, one at 1/3, and one for example in 1/5? I would try to model this, but Leonard Audio software only supports one driver location.
I can model this in Akabak pretty easily with multi drivers. Get me your drawn to scale sketch of the profile and driver locations. If you put the drivers at 1/5 and 1/3 they are quite close together and can be approxinated as dual drivers at the mid point between 1/5 and 1/3. Also, if you provide the dimensions of the short TL for the top as well as cabinet width and driver locations son baffle I can model the whole system response with XO and baffle step and diffraction. Also indicate how far away your back wall is and that reflection will also be included.
FWIW, this is the quick & dirty line as I designed it in post 4, complete with horrific response problems caused by the 1/10 tap location insufficiently supressing the pipe harmonics.
It was there to allow closer placement between the drivers. Personally, I didn't think it was such a bad compromise, but YMMV as always of course. :sad:
Here's a link to the image in pretty big resolution: http://i.imgur.com/R6x6e6A.jpg
The TC9 line lenght from center to end is 300mm. All widths are 270mm. If you want, could you also simulate one driver at 440mm from top, 345mm from line center (the topmost bass driver) alone. It's pretty much as far as I could go from the full range without issues. Back wall will be about 330mm away from from baffle edges. The edges will be rounded, but I doubt it can be simulated for. Last, but not least, the line lenght is about 131cm.
Thanks in advance!
EDIT: I have only faint clues on how drivers should be placed on baffle. Maybe bass drivers on middle, full range about 30mm from one side? It gave the best result on EDGE simulator.
Simulation of FAST TL
Using the geometry of the design from your earlier post: http://i.imgur.com/R6x6e6A.jpg
I modeled it in Akabak. The main bass TL is quite good with two drivers - nice sensitivity of 91dB at 2.83v, a smooth response with an f3 of 55Hz and smooth rolloff like a pro audio speaker:
The HF TL however has a pronounced peak with a 10mm terminus, which does not give a very smooth XO:
If we reduced the terminus to 1.3mm, it is much better:
Here is the combined response of the bass TL and the HF TL using a 300Hz -24dB LPF for the bass and a 370Hz -24dB HPF for the top:
As you can see, the sensitivity of the woofers overwhelms the TC9FD, you would need to run it at 4x the voltage to compensate and that is not good. Alternatively, a 91dB sensitive driver like the Faital Pro may work better here.
The simpler way is to run the bass TL with only a single driver, the volume has doubled so the tuning will drop lower and the f3 is at 41Hz. The TC9FD now requires 1.6x gain relative to the the woofer, and a BSC circuit using a 0.8mH coil and a 6ohm resistor to level the response:
The problem with this driver in a TL like this is that the cone motion control is not very good, as 4 mm of xmax is reached at only 7 volts drive on the woofer - this really limits your max SPL levels:
460749d1421909297-fast-tl-fast-tl1-1.6x-tc9fd-bsc-single-tc18wg49-combined-displacement.png
Here is the frequency response at 2.83v drive on the single woofer:
Here is the impulse response, quite nice:
460751d1421909297-fast-tl-fast-tl1-1.6x-tc9fd-bsc-single-tc18wg49-combined-impulse.png
So in summary, I think the major findings are:
1. Use a single woofer if you want get closer to balanced levels with the TC9FD (still needs 1.6x boost)
2. Use a 300Hz -24dB/oct LPF for the woofer and 370Hz -24dB/oct HPF for the fullrange
3. Make the terminus gap on the top TL 1.3mm vs 10mm
  • FAST-TL1-1.6x-TC9FD-with-BSC-and-single-TC18WG49-Combined-Displacement.png
1. The maximum SPL isn't really desirable in this build, as my friends lives in an apartment building. Listening will be done at moderate volumes. The thought of using two drivers is a nice one, but ordering the faital pro driver would break the budget set by my friend.
2. Interesting points. As I'm planning on using PLLXO (budget constraints), the maximum would be 2nd order with Q of about 0.5. It's interesting that this is actually cheaper to do as an active build than passive as the big chokes for low-frequency crossover cost a fortune.
3. Good tip on the full range TLs terminus, it's easier to make smaller by just adjusting the angle of the board separating the TLs. Why does it need baffle step though?
What kind of damping did you simulate in these? By default, I was thinking of lining all internal walls with 8mm felt and build up from there if necessary.
EDIT: The shortfall of this Leonard Audio software is that it can only simulate one instance per time. So, had to run two instances to get both drivers along. Here's my take on the 1/5th down the bass TL line for simulation.
attachment.php
