The Aleph Design Reloaded
It is best to draw my own PCB single side: D
Criticism and praise are welcome.
Best Regards
Break the trace between GND and -IN, add pads for jumper.
Balanced input (XLR) needs that separated, but if the builder will use RCA exclusively, the jumper can be installed.
Can you also add pads/holes on the capacitors for 7.5mm and 5mm lead spacing?
