Cool simple "clean" CFA
Hi Jeff, interesting - I didn't notice this specialty with regards to input cabling. Maybe I just had the right cabling all the time - I don't know 🙂
For BJT outputs, you need:
Q18, Q22 = NJW1302
Q19, Q23 = NJW3281
R42, R43, R52, R53 = 100R
R44, R45, R54, R55 = 2.2R
No PCB changes required - which is pretty cool 🙂
Do any of you know if I can use MJL4302 / MJL4281 instead of NJ1302 / NJW3281?
Hi Guys,
The boards arrived today so those of you who want some, please PM me.
I built a pair but haven't attached them to a heatsink yet so haven't tested them. Hopefully this week.
Blessings, Terry
Curves are nice🙂- are you on vacation?
Thanks Valery🙂
OK, I have finally reached my server remotely and have built the curves.
They are pretty "clean", as promised in the thread title 🙂)), showing the following key parameters (rounded values):
ULGF: 1MHz
Phase Margin: 84 degrees
Gain Margin: 20db
CLG: 29db (set by global NFB)
OLG(1KHz): 57db
LG(1KHz): 28db
OLG(20KHz): 35db
LG(20KHz): 6db
In overall, this is a rather low LG, high-linearity design.
Valery
Here goes a simple one! 🙂
Ready for something new? 😉
Greetings from Switzerland, I'm still here. Skiing was limited during the last couple of days due to avalanche danger - no problem, spare time was used for testing some front-end ideas 😛
Of course, not prototyped yet - I will work on PCB over the weekend - however it is simmed thoroughly and looks very promising.
Only 8 active devices (excluding DC servo). Compensation - single lead cap. All the rest is done by the FETs' internal capacitance. Very simple. DIYer's dream 😀
JFET input stage, JFET-MOSFET "super-pair" VAS stage. That's basically it. Two BGTs are used as a cascode (common base) for limiting the input JFETs drain voltage.
Developing this front-end, I actually had in mind my simple Lateral-FET OPS from TubSuMo project. Partially for that purpose, VAS is running at high current (20mA). If somebody wants to use it together with other OPS modules, designed for lower VAS currents (4-5 mA) - no problem, one can change R1, R3 to 43R. Similar performance with probably very slightly higher THD at 10-20KHz.
Attached files represent:
1) Front-end schematic;
2) Front-end together with Lateral-FET OPS (all further measurements are done for this particular combination);
3) Clipping behavior - nice, soft, rounded corners;
4) Closed loop frequency response (left edge is 100 Hz);
5) Closed loop phase response (left edge is 100 Hz);
6) THD @ 1KHz (simulated value);
7) AC analysis - Phase Margin;
8) AC analysis - Gain Margin.
Key parameters (so far - per simulation):
Output power - up to around 120W @ 8R (with +/-52V rails);
Voltage gain: 29db;
ULGF = 1.625MHz;
Phase margin: 86.5 degrees;
Gain margin: 26db;
THD @ 1W: 1KHz<0.001%; 10KHz=0.002%; 20KHz=0.006%;
THD @ 50W: 1KHz=0.003%; 10KHz=0.016%; 20KHz=0.038%;
Pretty cool, especially at lower volumes. Would be interesting to audition.
All for now, have fun, stay tuned - further development will follow 😉
Valery
Voltage gain: 29db;
ULGF = 1.625MHz;
Gain margin: 26db;
Valery
Hi Valery! FYI -- this is exactly the topolgoy I use for almost 40 years now.
THx-RNMarsh
