I made a couple more changes to the file. C9,10,14&15 were shorted. I fixed them. Gain is pretty low. I tried lowering R24 to 50R and that brought up the gain but raised the THD quite a bit. Maybe there is a better way to raise the gain.
Blessings, Terry
Blessings, Terry
😀 It's a trade-off, Terry. Many people do not understand about the effect of feedback. There's debate about the importance of feedback. Those who debate do not understand. If they understand, they will put the right amount of feedback into the circuit. People tried to lower the THD as low as possible, not knowing what they throw away with the bath water.
Preamp ?
A preamp doesn't raise the gain, it only raises the input voltage. I don't know yet with the real amp because I haven't found my problem yet but on the spice file, 3vac on input only outputs 45vac on the output. I think that is a gain of 15x. Lower than any amp I've built so far.
This is a tough amp to troubleshoot with 33 transistors. They all measure good with a diode test so I must have a solder bridge somewhere. I'll stay after it. If I can't find it I'll post up a schematic with voltages for some fresh eyes. The good thing is that we know the board will work because Alex has already proven it.
Blessings, Terry
Blessings, Terry
Only 45vac on the output is over 500W/4R. Replace R25, R26 and R27 with 1k instead 470R, gain will increase to 30x.
Yes, I understand it is a lot of power but 3v input is higher than most preamps will output. I changed the three 470R to 1K each and as you said I see 30vac with a 1V input.
I'm attaching the error report from Ltspice.
Blessings, Terry
CFA amplifier with advance output stage.
I know why it is called A40, there is 40 transistors in it, WOW. Nice.
What is max rail voltage for it ??
THX
Peter
THX
Peter
+/-65V,
A pre-amp that raises the input voltage has gain.A preamp doesn't raise the gain, it only raises the input voltage. I don't know yet with the real amp because I haven't found my problem yet but on the spice file, 3vac on input only outputs 45vac on the output. I think that is a gain of 15x. Lower than any amp I've built so far.
Blessings, Terry
That gain adds to the system gain.
eg.
A Buffer with a gain of +0dB feeding a Power Amplifier with a gain of +26dB results in a system gain (for these two components) of +26dB
Replace the Buffer with a Pre-amp with a gain of +10dB which increases the input voltage to the Power Amplifier by about 3.1times, gives a system gain of +36dB
reduced by two transistors and now it is A38 - used Olaf´s files from earlier done A14 and A33 - so it has all rights to be called Olaf´s and accommodated by me:
(!!!IT MUST BE CHECKED!!!)
Nice work,
Hi, I started with the modules for my A9-Amplifier. Because of the ease installation I have changed the layout, so that a BD139 can be mounted on the heatsink. If anyone needs the layout, I can post it.
regards Olaf
Hi Olaf,
Can you Please post the foils for this.i would like to make a pair.
Thank you.
Rick.
No need to mention the copyrights 🙂.reduced by two transistors and now it is A38 - used Olaf´s files from earlier done A14 and A33 - so it has all rights to be called Olaf´s and accommodated by me:
Looks very good !
regards Olaf
Hi, here are all the necessary files (zip includes the Sprint-File).Hi Olaf,
Thank you.
Rick.
Regards Olaf
A40 PCB not tested yet ......
Nice works guys ,and my last layout not tested but very soon I will build a pair😀
Alex
Alex
Alex
Nice pcb,
- 100W Ultimate Fidelity Amplifier
