Ultra-high performance, yet rather simple - hybrid and more!
This input board is being stubborn! It wants to output negative no matter what I try.
I mean, the LED is like a Zener - it keeps the voltage drop almost unchanged in a certain range of forward-currents. The red one keeps the V-drop somewhere at 1.75 (+/-0.3) V and it does not slip in normal conditions.
One more thought - can it be somehow, that PCB ground is not really connected to PSU ground? There are two points at OPS PCB, that have to be connected with a thick wire - GND1 and GND2. I had this wire poorly soldered in the very beginning and it drove me crazy until I realized that my IPS Groud is floating...
I have analyzed your voltages in more detail - it looks like the part of the circuit, showing inadequate behavior, is the bottom part of VAS (Q9, Q12, Q13).
Is Q9 = BC560?
Having zero over R33, you should also have zero over R44. But your voltage over R44 is higher than the one over R41, meaning that the bottom half of VAS pulls stronger, giving you -41.7V at the output, despite the fact that all the rest of the circuit is trying to pull it up, balancing the output to zero offset. Can you please check the bottom-right corner.
Is Q9 = BC560?
I've rechecked every resistor on the board and gave up and replaced every transistor on the board(I hate blindly changing parts). Now I have lower DC offset and 2 volts across the output. I'll mark up another schematic in the morning and order some more LEDs out of Newark. The traffic light LEDs are meant to run at much higher current and will fail quickly at low current so I don't really trust them to do the job.
