ExtremA, class-A strikes back?
I fitted components to the PCB according to the simulation model created by BV. Today I could measure how the new circuit works.
@BV,
Thanks for the feedback and the .asc. Could you perhaps post a list of changes and explain what you've done exactly. I can see a number of diodes being added, some others removed and a variety of capacitors being added, as well as multiple RC networks being added/changed.
I am very curious about results that JMD01 will get from the modified circuit. I believe he will share the results with us.
This is the amplifier built that I have measured and analyzed in Prague and posted some measurements here.
Ah, excellent, if JMD01 is willing to explore other options as well I'd be very interested in seeing the results of the less invasive modifications I've proposed previously.
